XSim: 3rd and 4th order blocks? - diyAudio
Old 12th January 2016, 10:01 PM   #1
eriksquires's Avatar
Default XSim: 3rd and 4th order blocks?
Hi Everyone,
Sorry if there is a rule of thumb I'm missing. I use Xsim a lot and notice that there's no 3rd or 4th order circuit blocks.
Is there an easy rule of thumb to combine 1st and 2nd order filters into higher orders? Like, if I wanted a 4th order LR do I add a pair of 2nd order somehow?
Erik
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 13th January 2016, 02:53 AM   #2
AlexQS is offline AlexQS  United States
Eriksquires,
I don't know about XSim, but functionally, I think it should be the same as what I'm using: Active Crossover Designer. software
Even if you don't want to use the software, download the ACD zip so that you can read the manuals, there's a table that answers your question and more:
"LR4 crossover requires two second order filters, each with a Q=0.707. The filter corner frequency is equal to the crossover point for LR type crossovers". Quote, Charlie Laub.
Old 13th January 2016, 03:48 AM   #3
Thanks!
I can find calculators online for all that, I was just curious. It's easier with the Circuit Blocks because I can just click up or down on the F3 point without having to reset each component value.
Best,
Erik
Old 13th January 2016, 03:59 AM   #4
Oh I see, that would be convenient.
I just think it's super nice of Charlie to have all that software and information available to us. Before I discovered his site, I didn't know if that for Bessel, or BW4, or LR8 etc, just add these xyz etc filters. I love the table showing what all the Q needs to be, etc.
Does XSim do the same thing, crate Biquads that can be used by miniDSP or the like?
Alex
Old 13th January 2016, 04:31 AM   #5
Sorry, no. Xsim is passive only.
Old 13th January 2016, 05:32 AM   #6
bwaslo is offline bwaslo  United States
bwaslo's Avatar
A 3rd order crossover is only a second order one preceded with or followed by a first order one. A 4th is two scond order ones in cascade. They aren't offered as separate blocks because beyond 2nd order there's no simple way (like a value for Q) to specify them. So you can configure topologies (at least) by making them from 1st and second order blocks.
The apparently obvious choices of letting you specify as Butterworth, Chebychev, Bessel, etc. wasn't done mostly because crossover filters are always applied to drivers that already have multiple orders of filtering already in their responses - specify whatever electrical named response, you won't get it really since the driver is already filtering before you do. So it didn't seem worth much of anything, not even considering the significant effort it would take. (Though has anyone noticed that you can create your own Circuit Blocks in Xsim if you can get a formula for the component values? ... gets pretty ugly for complicated things, though).
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 13th January 2016, 05:47 AM   #7
Bill,
Thanks so much for getting back to me. This makes sense, but I'm wondering if I am missing something. I get what you mean about crossover topologies used with real-world drivers not making a lot of sense. My main question was, am I missing something if I try to create a filter of order n>2? For instance, given an ideal driver, if I wanted to start with a 3rd order filter at 2kHz, do I just use a 1st and 2nd order Circuit Block with the same corner F?
Looking at the handy dandy online calculator from V-Cap for 4th order LR filters for instance, it seems that cascading two identical 2nd order filters is not what I should do. I seem to be missing part of the recipe after the 2nd order filters.
My main goal is really to use the Circuit Blocks as long as I can before I start to tweak individual values. Having 2 circuit blocks to tweak is still much better than 4 individual components every time I want to nudge the corner F up or down.
Thanks!
Erik
Old 13th January 2016, 06:42 AM   #8
bwaslo's Avatar
No, the component values will interract too much for nice rules of thumb to help much, sorry. But I'd place the first order section (if odd order) and 2nd order sections all down and play with nominal impedance, frequency and Q values (don't take the ohm, Hz and Q values literally then, just use them as knobs on each section to move things around with a little more stability than tuning RLCs individually) till you get somewhat close...then convert to separate components and hand tweak those).
Old 13th January 2016, 06:49 AM   #9
So, alternatively, could I examine the impedance for the new circuit, and then create a new block based on that?
For instance, I add a cap to a tweeter. The impedance at 2kHz now goes from 8 ohms to 32. Now could I add a 2nd order filter, with an impedance of 32 ohms at 2kHz? Would that get me in the ballpark?
Best,
Erik
Old 13th January 2016, 07:22 AM   #10
bwaslo's Avatar
not really, its a filter. Impedance at one frequency doesn't specify a lot. Easiest and probably best is to just put the structure down (assuming you know what it looks like) and twiddle knobs to get near what you want. Easier than trying to calculate or approximate, you'll quickly get a "feel" for it. Then after converting to parts, you can also insert resistors in series or across Ls and Cs to smooth out usually.
Circuit Blocks are subnetworks for which component values can be defined by the designer via formulae of other parameter values. You can put yourself in circuit block development mode to play if you want (the tool isn't very forgiving of errors though, but I was able to use it to make the blocks that are included in Xsim - not for the fainthearted and the tool could stand a lot of polishing).
XSim : Impedance and Power in 1st vs. 2nd Order Filters eriksquires Multi-Way 30 15th December 2015 08:55 PM
2nd, 3rd, 4th order closed box Dshelton68 Multi-Way 15 4th April 2015 10:55 PM
advanatge of 1s order over 2nd or 3rd order? Professor smith Multi-Way 149 23rd September 2010 05:43 PM
2nd Order Tweeter + 3rd Order Woofer = OK? Jay Multi-Way 3 12th September 2005 01:12 PM
1st Order Tweeter, 3rd Order Woofer? Jay Multi-Way 8 8th May 2004 10:29 PM
Copyright 1999-2017 diyAudio
