Yamaha NS-1000M active crossover? - diyAudio
Old 10th January 2016, 01:42 PM   #1
Default Yamaha NS-1000M active crossover?
Greetings.
I am researching a possibility to change my Yamaha NS-1000m speakers from passive to active.
500 Hz crossover would be active and 4500 Hz crossover would be passive (since I will do bi-amp, not tri-amp)
Original design is 2nd order, but it seems that Troels Gravensens updated crossover is 3rd order?
Does anyone have experience about NS-1000M with active crossover? I would imagine best active would be simulating Troels Gravensens improved crossover...
Link to improved XO by Troels Gravensen.
Old 10th January 2016, 07:16 PM   #2
eriksquires's Avatar
Originally Posted by XScorpius View Post
Greetings.
I've been toying around with a similar idea for a center channel. What about a Hypex plate amp? Has amp + DSP built in.
It makes sense to keep Gravesen's tweeter and mid low pass filters but you would not want to emulate Gravesen's mid-woofer filters. Taking full advantage of the DSP processing you should delay the tweeter/midrange channel so the acoustic offset between the midrange and woofer is 0.
This will cause the two sections to have different phase matching than with a purely passive design, so Gravesen's design won't work as-is. You'll need to design the active crossover based on your own tests.
Best,
Erik
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 25th June 2016, 06:19 PM   #3
0vid is offline 0vid  England
Yes I tri amp my NS1000Ms
FS-YAMAHA NS-1000M mclsound Swap Meet 4 28th April 2013 07:00 PM
WTB: Yamaha NS-500M or Yamaha NS-1000M speakers Aerolite360 Swap Meet 0 28th February 2013 02:58 AM
Yamaha NS-1000m Response Tenson Multi-Way 3 15th July 2009 08:25 PM
Yamaha NS 1000M wanted fishdaddy58 Multi-Way 11 1st April 2008 07:12 PM
NS-1000M parts XEAGLEKEEPER Multi-Way 8 19th May 2007 09:10 PM
Copyright 1999-2017 diyAudio
