A Bookshelf Multi-Way Point-Source Horn
Old 6th October 2017, 07:59 PM   #1591
Brinkman is offline Brinkman  United States
Originally Posted by Patrick Bateman View Post
@Sheldon owns Unity horns that look like this:
Are these the ones?
My wife even thinks they're beautiful, which is more or less a mandate to build a pair of Bill's newest horns (as planned) and give them a similar look.
Old 13th October 2017, 04:15 AM   #1592
Chris8sirhC is offline Chris8sirhC  United States
Send a message via AIM to Chris8sirhC
<snip>
Bills designs: link? Or the design on page 1 of this thread. What's the best larger design out there?
Old 13th October 2017, 09:27 AM   #1593
4real is offline 4real  Netherlands
I think he means the Small Syns. But neither this thread nor the Small Syns are large designs. They are meant be be relatively small
I'm wondering if there is another solution: what if you would take the simple 2-way design that is proposed here, and make it an acoustic resistance box by making some stuffed slots in the side panels. That would also take care of the lower down directivity, but does not need a box that is much wider or higher than the horn itself is.
Do diamonds shine on the dark side of the moon?
Old 13th October 2017, 01:25 PM   #1594
arcgotic is offline arcgotic  Romania
I went with a big conical horn, a single 12PE32 12" driver for 110-500, entering near the throat in a 180 sq. cm. port. The cone throat is 25sq.cm area.
Did some tests with:
- Faital Pro 3Fe25 as full range. Not enough highs.
- Faital Pro 3Fe25 + Seas 27TDC tweeter suspended in center of the horn mouth. Sound was good.
- Faital Pro 3Fe25 + BMS 4524 in a OS horn. Sound is even better.
- today I bought the SB Acoustic SB65WBAC25-4. I will try it as fullrange, I want a simple 2way.
For subwoofers, I have sealed box but sometime I feel they don't integrate good with the horn loaded mid-bass. I am assembling a TH with B&C 10CL51 now, in simulation it looks good.
Old 18th October 2017, 08:18 PM   #1595
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Not sure of what you had in mind but a made a foam Trynergy with woofer rear cone output going out a slightly damped open back. Bass was quite nice.
Presenting the Trynergy - a full range tractrix synergy.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 18th October 2017, 08:20 PM   #1596
Got Foam?
xrk971's Avatar
A TH is a good idea for powerful bass. The hardest part is getting it to gonhigh enogh to cross with horn at 120Hz or so. A front loaded bass horn is better here as can go up to 300Hz easy.
Old 19th October 2017, 06:32 PM   #1597
Yes, something like that. Did you do polars of that one? In my idea the dampend holes would be on the sides though.
Old 19th October 2017, 07:21 PM   #1598
onni is offline onni  Sweden
That sounds a little like my synergy experiment:
/Anton
Old 20th October 2017, 06:39 AM   #1599
Yes, that is what I mean. Looks like pretty good pattern control up to almost 90 deg over the whole band.
Old 20th October 2017, 08:44 PM   #1600
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
That looks pretty nice, Onni. What kind of efficiency did you get in the bass?
Did you make a pair or just the one?
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
A Bookshelf Multi-Way Point-Source HornHide this!Advertise here!
SynTripP: 2-way 2-part Virtual Single Point Source Horn weltersys Multi-Way 724 Today 06:36 PM
Red Spade PSE-144 unity ,point source elliptical Horn, w/xover, 250-20khz hum4god Swap Meet 10 13th February 2016 03:30 PM
Need Help with Point Source Monitor!!! MikeDavidBeats Multi-Way 8 30th January 2014 05:02 PM
