Rare folded horn Opus 1
Old 6th January 2016, 04:10 PM   #1
Walloffound is offline Walloffound  United States
Walloffound's Avatar
Default Rare folded horn Opus 1
Has anyone ever seen or heard a Stan White Opus 1
I'm trying to figure out what were the original drivers or something that would work for this cabinet 8" and 5" holes.
They were made in 1957 and may have had Quam Nichold speakers the holes are shallow.
Old 7th January 2016, 02:27 AM   #2
Hey everybody, it's my first post... Anybody there ... Mic check one two...
Thanks for any thought you might have
Old 7th January 2016, 04:57 AM   #3
freddi is offline freddi  United States
freddi's Avatar
all I know is that must be very rare - I heard that Stan had some very big (and loud) speakers with high power amps for some of the early HiFi shows. What are the dimensions including the mouth? - can you figure out the path and expansion? It would be interesting to load it, get input impedance and see what it does. ( "White cathode-followers" are cool )
ah - here's a page on the Opus 1 http://www.itishifi.com/search/label/Stan%20White
Old 7th January 2016, 08:41 AM   #4
ErnieM is offline ErnieM  United States
Neat little box! A modern 8" fullrange/prosound driver would probably do better than the original. Can you measure the depth to help narrow down possible replacement drivers? I would cover up the 5" whole and maybe put a nice little 2" or 3" fullrange for a mid tweet. Or keep it super simple with a nice fullrange 8".
Old 7th January 2016, 09:55 AM   #5
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
A sketch of what the dimensions and horn geometry/flow arrangement would be very useful. I cannot picture what is going on from the photo. It is indeed rare.
Old 7th January 2016, 02:46 PM   #6
freddi's Avatar
perhaps we can find Stan's patents - here's a nice brochure http://www.technicalaudio.com/pdf/Go...udspeakers.pdf
here's one blh patent https://docs.google.com/viewer?url=p.../US2866513.pdf
Old 7th January 2016, 03:23 PM   #7
Thanks y'all !! I will take some measurements and try to see what is going on inside. The one I have has the opening on the bottom and not the front, the way it looks in the patent. I can tell you that the corners of the inside folds are rounded off with the addition of curved piece of linolium. I found one guy on this forum who built one and I private messages him but he hasn't been active in a while. I was hoping to restore this piece to original since it's sort of rare. But it turns out that the original had seemingly unimpressive PA type Quam-Nichols drivers. I have a Jansen PA8 driver but the square magnet is just a bit too wide to fit into the existing round hole. I just wanted to do some research and consult the experts before starting to hacksaw things. I'm a beginner of audio so I really appreciate your help and experiencen.
http://www.diyaudio.com/forums/multi...over-help.html
http://www.diyaudio.com/forums/multi...roduction.html
Old 8th January 2016, 03:52 AM   #8
Here are the measurements:
Old 8th January 2016, 07:11 AM   #9
"The horn has an equivalent axial length of 12 feet" - from the brochure
Old 8th January 2016, 07:19 AM   #10
freddi's Avatar
very cool and nice drawing - be interesting to see how it measures once loaded with a woofer
Rare folded horn Opus 1Hide this!Advertise here!
jbl gto804 tapped horn/ folded horn 2009thread1 Subwoofers 103 6th December 2015 06:26 PM
Tapped horn vs folded horn bcodemz Subwoofers 19 8th June 2015 07:07 AM
Folded horn - volume between subwoofer cone ane th start of the horn benpalmer Subwoofers 8 9th April 2012 01:10 PM
Entering horn meaurements fora folded horn (hornsrep) Tidy Max Software Tools 3 21st February 2011 02:28 AM
how to go from horn response to a folded bass horn design? paulspencer Subwoofers 8 4th November 2005 10:44 PM
