would the Eminator 1508 make a decent big boombox woofer? - diyAudio
Home Forums Rules Articles diyAudio Store Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Old 1st January 2016, 08:14 AM   #1
freddi is offline freddi  United States
freddi's Avatar
Default would the Eminator 1508 make a decent big boombox woofer?
I have a few speakers which could be employed including 10" coax, 8" coax, 8" and 10" fullrange, but in my pile are some 1508 Eminators
a cabinet might be in the two cubic foot internal volume region/ 3/8" Baltic birch with a TPA3116
opinions and suggestions on tunings/volumes are welcome if you think it would make the foundation of a good sounding sensitive boombox
Resonant Frequency (fs) 82.68 Hz
DC Resistance (Re) 6.7
Coil Inductance (Le) 0.68 mH
Mechanical Q (Qms) 2.98
Electromagnetic Q (Qes) 0.74
Total Q (Qts) 0.59
Compliance Equivalent Volume (Vas) 14 liters/ 0.49 cu.ft.
Peak Diaphragm Displacement Volume (Vd) 70.7 cc
Mechanical Compliance of Suspension (Cms) 0.22 mm/N
BL Product (BL) 8.95 T-M
Diaphragm Mass inc. Airload (Mms) 17 grams
Efficiency Bandwidth Product (EBP) 111.98
Maximum Linear Excursion (Xmax) 3.3 mm
Surface Area of Cone (Sd) 214.1 cm2
Maximum Mechanical Limit (Xlim) 6.5 mm
Old 1st January 2016, 09:26 AM   #2
freddi's Avatar
any bites? a small waveguide and compression driver could do the treble work - maybe a WG loaded dome - - not sure if a piezo would be worth the trouble but could save money
schematic
tuning
spl 1 pi 30 watts
displacement at 30 watts
Old 1st January 2016, 10:12 AM   #3
Sonce is offline Sonce  Macedonia
Two cubic foot = 56.6 liter, much larger than 21.7 liter cabinet simulated.
Old 1st January 2016, 10:28 AM   #4
freddi's Avatar
two cubic foot is for the whole box to hold two woofers, two tweeters, battery and amplifier
The HeavyMAN! One big *** boombox! Buzzyll Class D 17 18th May 2014 10:59 PM
New Here, Would like to make Suitcase Boombox Schwarttzy Class D 7 13th September 2012 07:22 PM
Big Boombox Cal Weldon Multi-Way 45 23rd May 2011 03:53 AM
Can you make a decent enclosure out plastic or metal boxes? chico1st Full Range 11 12th May 2011 11:28 PM
Cheaper to buy or make decent inductors. cbdb Multi-Way 7 17th October 2010 05:31 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
