What would it take to start measuring the frequency response of speaker drivers? I would like to learn how to do this, and start building speakers.. What's involved? Tia
#2 |
Google is your friend.
http://yu-ra.tripod.com/ts_parameter.htm http://sound.westhost.com/tsp.htm Also, pick up a copy of The Great Sound Loudspeaker Manual. It has an easy to understand explanation and pictures on how to measure drivers along with some projects. |
#3 |
Hello,
you will need the hardware and the software to do it, and it will cost you from few euros (depending on what do you already have) to hundreds of €. A cheap way is using Speaker Workshop as software and your computer sound card as hardware: check my site to have a better idea; be aware that it isn't a P'n'P solution, you need to spend time to achieve a sufficient knowledge. Expensive (but ready to go) solutions are Clio and MLLSA; with an oscilloscope you can get some measurements too. Regards Claudio |
#4 |
if you have a computer:
behringer ecm8000 mic + preamp with phanton power = $95 US RTA software - Free for the basic options on some good programs...better options would be the level 3 TrueRTA for $70 US http://www.trueaudio.com/rta_abt1.htm |
#5 |
Check out Eric Wallin's audio page at http://www.gti.net/wallin/audio/audio.html for Speaker workshop tutorials and DIY hardware to make it all work.
Cheers |
#6 | |
#7 |
Timn8ter, thanks for the book title. That looks like it would be something manageable.. Also, (to everyone) is it necessary to measure the frequency response and parameters of a speaker? Many companies seem to supply it, so what exactly is it used for? Does it have to do with building the crossover? Maybe after you design a crossover you do a frequency response test to see how flat the system came out or something?? tia
Dave |
#8 | ||
http://www.decware.com/new%20site/mainmenu.htm Read Steve's article titled "How to Design a Speaker". Quote:
#9 |
Would say pick up a copy of Great Sound Stereo Speaker Manual by David Weems first and read it thoroughly. It is really a good book to start with (one of the best IMHO) and also fun to read. It will make a lot of things clear. After then you can decide if you really need to invest in measurement stuff. IMHO measurement is not the first thing you need when you want to DIY loudspeakers. Cheers BTW. Weems book comes with CD loaded with free (DOS) design software. However no measurement software. |
| Measuring Frequency Response | MCPete | Multi-Way | 10 | 10th February 2009 12:36 AM |
| Measuring Frequency Response | furly | Planars & Exotics | 1 | 17th March 2006 06:59 AM |
| Measuring the frequency response of a mic? | mr_push_pull | Multi-Way | 5 | 30th August 2004 12:26 PM |
| Page generated in 0.11770 seconds (78.18% PHP - 21.82% MySQL) with 10 queries |
