advice needed on TL
advice needed on TL
Old 16th December 2015, 04:53 PM   #1
SS4927 is offline SS4927  Canada
SS4927's Avatar
Default advice needed on TL
I might of done alright on some narrow columns someone gave, but they didnt have info to offer about them, like what make for starters? The badges are missing. They have 6" mid bass' and 1 1/8" soft domes.
We plugged them into an amp and I wasnt impressed. Bass is very weak and poorly placed. But they sound kinda nice otherwise.
Having a closer inspection I realized there TL's, and I thought sweet. But wheres all the bass going? Polarity is correct. Then I realized the slot ports at the bottom rears are missing, crap. 7"x 2 1/2" gaping holes dont seem to be working. What should I do?
I could easily make some with ply. But I dont know where to start for the sizes.
Old 16th December 2015, 04:58 PM   #2
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Maybe some polyurethane soft filling had collapsed inside the line making a stopper.
Old 16th December 2015, 05:14 PM   #3
system7 is offline system7  United Kingdom
system7's Avatar
We had this same question recently.
PMC TL Stuffing
I suppose you have to google the model and try and figure out what port size and stuffing is appropriate.
Best Regards from Steve in Portsmouth, UK.
Old 16th December 2015, 05:35 PM   #4
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
advice needed on TL
Pictures?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th December 2015, 08:19 PM   #5
GM is offline GM  United States
GM's Avatar
Hmm, a TL's 'vent' opening [terminus] is the same area as the TL with a smaller vent making it a MLTL in today's parlance, so are you sure it originally had a slot vent?
Regardless, will need all the woofer info, TL dimensions, etc., for us to be of any help at all. For now, I'm guessing they primarily just need some baffle step compensation [BSC].
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 17th December 2015, 03:30 AM   #6
SS4927's Avatar
GM
That's what I started thinking, that they might not of had any. I was actually returning to question that thinking of PMC and having fresh looks at some. As I made my approach I thought there WERE PMC, they bared a striking resemblance. Turns out I almost crapped my pants for a lot less potentially doubling my embarrassment. They are SONY transmission lines. Loosely put it appears someone upgraded them. Or downgraded them with better quality tweeters. Sorry about that. So what should I do with them now, gut and put in full range drivers? The cabinets are nearly mint.
Old 17th December 2015, 04:31 AM   #7
xrk971 is offline xrk971  United States
xrk971's Avatar
advice needed on TL
Photos and dimensions would be useful as well as the Sony model number if you know it. I never knew Sony built TL speakers.
Old 17th December 2015, 04:40 AM   #8
frugal-phile(tm)
planet10's Avatar
advice needed on TL
Like these?
dave
Old 17th December 2015, 05:04 PM   #9
SS4927's Avatar
I didn't know sony made TL's either, apparently there are 3 models in this line, the SS TL1 being smallest. They look a lot like the ones you posted planet10. Only taller/thinner, the camera might be adding 10 lbs
I think I could live with these at least in my shop but Ill try to do them better providing parts I have compliment them better. I have spare silk polydax and textile morel's Im not using.
By the way I found the bass, and lots of it. It sounds like a sub is running its that robust. For small speakers they go nice and low. It can stand for improvement there. Some of the stuffing is missing its bare wood in the lower section around the vent areas.
In case your wondering the cause, polarity WAS off. I was careful when hooking them up. In a pinch sometimes Ill use generic electrical wire, printed half +, non print - . For some reason this stuff has printing on both sides . Have not seen that before.
I dont expect to be doing serious listening with them but Ill have a little fun trying to get them dialed in. The cabs are heavy and solid. Those are about the best thing they have going for them. I still like the idea of finding a suitable full range to see how they work. Ill make a picture next time Im at the house they sit.
Old 17th December 2015, 07:12 PM   #10
GM's Avatar
You'd think that after all these years, I'd have learned by now that one can't assume anything with this 'crowd'. Checking polarity should always be the first test at every step of the way when wiring is involved.
Anyway, not surprised at its bass performance as early Sony and similar brands were all 'voiced' with more than a nod to then current 'Just Big and Loud' speakers , though again, will need either measured driver specs or at least cab internal dims to maybe find some modern drivers to work.
If these are like many of their consumer speakers though, you'll need to be looking at cheap ceiling PA, mobile audio offerings to get the desired specs.
GM
advice needed on TLHide this!Advertise here!
Help with 8' TL Sub Needed Cambe Subwoofers 10 17th February 2012 03:36 PM
Need advice on a TL build IG81 Multi-Way 27 30th September 2010 03:28 PM
New to the TL forum and need advice djn Tubelab 0 1st March 2010 05:07 PM
need some classic tl advice galac Multi-Way 8 23rd November 2007 10:52 PM
Best TL subwoofer, need advice. Gunawan W Subwoofers 0 4th January 2004 02:44 PM
