Really great forum. It made me build Gainclone based on LM3875 which sounds amazing to me. I believe in the “Less is more” approach.
Lately after building a Gainclone and mod’ing my CDP I started hearing things I didn’t before. I’m getting a totally different (much better) soundstage (width and dept) and I’d like to improve on that. I think it has a lot to do with the speaker’s phase response. So I’m wondering if I can improve the current speakers filters. Right now they have the sec. order LC filters on both speakers and no Zobel. The Cap on the HF speaker is paper type and the LF cap is electrolytic Non-Pollar type. The only thing I did that improve drameticly the soundstage was placing weather strips next to the HF speacker wich helped a lot with the focus and the spaciousness of the soundstage. I don't want to change the drivers or the cabinet. I’d really appreciate your suggestions. Those are the speakers I have. I’m very happy with the tonal balance. http://www.yamaha.ca/av/speakers/PDMSeries/NS200.asp /Greg |
#2 |
You can try better quality capacitors.
Do not add a Zobels, you'd need to redesign the c/o. Other tweeks without major changes are : 1. Experiment with lengthening the port to detune it for lower bass. (reducing diameter also works if you run out of length). 2. Damping the cabinet with cheap vinyl floor tiles. 3. Adding sand to the bottom of the speaker. 4. Upgrading the acoustic damping in the speaker, e.g. if its cheap Dacron, BAF, Polyfil to foam lining the cabinets. 5. Use blutack or similar to bed the drivers into place. 6. Blutack the speaker to a 10" x 10" concrete slab ( fairly easy to improve its appearance) and use 3 cones blutacked to the underneath for spiked floor coupling. 7. If you floor tile the cabinet use some bits on the bass unit chassis to damp it, specifically the chassis "legs". 8. Solder any push on connectors, you don't need to remove the connectors, just solder everything. 9. Blutack the terminal connector into place. 10. Glue a block of quality acoustic foam to the back of the bass driver. |
#3 |
Thanks Sreten,
Regarding damping with the floor tiles: I once did it on my CDP housing and after a while it all started coming off. Do you use a special glue or just the glue that's already on the back ot the tiles. I'll change the caps for sure. I had problems with the base reproduction in the livingroom. I guess the hight of the woofers is such that because of the standing waves in the room I can hear the base well but I have to be standing. In the normal sitting position the base is not that great and I don't want to just bump it up. I need to do something so that the SW distribution changes. Maybe if I rais the speakers up it'll soud better. I found out that if I mont them on spikes the base is very week and if I have spikes at the front but not at the back is much better. I have to keep experimenting I guess. From reading about filters I thought that Zobel on the base would be a good thing, but I don't have any experiance there. Thanks again for the suggestions! /Greg |
#4 |
Re floor tiles,
use the cheapest and thinnest you can find, these are the best. I use a small wallpaper roller, never had any problems. Re bass : Very unusual description, usually bass is better nearer room boundaries, and notoriously weak in the centre of the room & half room hieght. Spiking shouldn't affect bass balance the way you describe, in my experience, what type of floor do you have. Re Zobels : make crossover design easier but not the other way round. |
#5 | |
I have a thin hardwood floor and no cement/concrete underneath and below is the basement. It was very discouraging when I installed the speakers the first time (no base at all) until I found out what was happening. Regarding the spikes, I guess it decouples the speakers from the floor thus the floor resonates less, I don't really know. |
#6 |
frugal-phile(tm)
A couple things sreten missed:
0/ ductseal the speaker baskets -- if you could only do one mod this is it 11/ better wire 12/ brace the big panels -- you have to do this in a manner that doesn't eat up too much volume. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 | |
Dave, Tell me more about that, please. I'm not sure how to do that. /Greg |
#8 | |
frugal-phile(tm)
Here is a pic of an RS 40-1197 -- some should be added to the basket legs too (but the 1197 doesn't have much in the way of basket legs. dave
#9 |
frugal-phile(tm)
#10 |
Erm... your floor description gives outstanding qualities to a
thin layer of hardboard. So I assume you have a suspended wooden floor ? My best results with a suspended wooden floor and 1" of carpet & underlay was a homemade speakerstand with 3 4" chipboard screws driven through everything into the floorboards. The speakers where blutacked to the stand and using a finger is was impossible to wobble them, they felt architectural. Bass was lighter but bass/mid had far more attack and detail, |
| Yamaha CDX-550 mods: op-amp suggestions | Sparhawk | Digital Source | 7 | 25th December 2011 08:19 PM |
| New project... Yamaha RX396 Upgrade | Adrculda | Solid State | 10 | 24th August 2009 05:42 AM |
| Yamaha amplifier Upgrade | Macpibe | Solid State | 26 | 9th August 2007 04:21 AM |
| Suggestions for upgrade | kaban | Analogue Source | 13 | 21st October 2006 01:36 PM |
| Suggestions for Upgrade - VDV70/100 | gingertube | Tubes / Valves | 7 | 22nd March 2006 03:21 AM |
| Page generated in 0.11403 seconds (80.31% PHP - 19.69% MySQL) with 11 queries |
