Resistor placement of L-pad and single resistor - diyAudio
Old 7th December 2015, 02:32 AM   #1
Default Resistor placement of L-pad and single resistor
I know the best way to reduce dB of speaker is to use L-pad circuit that consisting of 2 resistors, one series and one parallel to the driver.
If using a single resistor and placing it after the crossover, nearest the driver, it will affect the impedance of the speaker and lead to the change of x-over point.
But what if I place that single resistor to BEFORE the crossover/filter. Will it affect the crossover point like placing AFTER crossover case ?
Old 7th December 2015, 04:10 AM   #2
Hi
You raise some good points, a 3 way design the gale GS401a answered
driver adjustment by placing the midrange adjustment as a series resistor
midway between two others, and the tweeter adjustment as a
series resistor prior to the capacitor seen in the attachment.
Most Gale owners dispense with driver pot adjustment and wire
fixed resistance to mimic the pots originally used.
So there is a bit more to this as drivers if adjusted by an L pad would
indeed be changed by the resistance of the driver most simply
expressed as R1xR2 / R1+R2.
Perhaps there is answer for your project by using
small values of series resistance suitably placed instead
of an L pad.
Cheers / Chris
File Type: jpg Copy-2-of-GS401-Speaker-Crossover-Schematic-4.jpg (621.5 KB, 55 views)
Old 7th December 2015, 04:40 AM   #3
AllenB is offline AllenB  Australia
I made a quick comparison here
Old 7th December 2015, 09:31 AM   #4
system7 is offline system7  United Kingdom
system7's Avatar
@ Chris Daly, that is the faulty schematic for the Gale.
The 7uF in the mid filter must go AFTER the 0.3mH or it's a dead short at high frequency!
Best Regards from Steve in Portsmouth, UK.
Midrange attenuation l-pad or single resistor? Sape Multi-Way 17 15th October 2015 09:54 AM
Attenuating Tweeter: L-pad vs Single Resistor mattiscat2 Multi-Way 8 12th November 2013 05:06 PM
L-pad vs series resistor AntM Multi-Way 1 29th July 2005 08:57 AM
Finding an L-pad or resistor... help? Feandil Multi-Way 6 6th April 2005 05:06 AM
Copyright 1999-2017 diyAudio
