Help - PMC TB1 speakers - replacement LF Woofer
Old 6th December 2015, 10:54 PM   #1
hallymusic is offline hallymusic  Ireland
Default Help - PMC TB1 speakers - replacement LF Woofer
I have blow one of the LF drivers in my PMC TB1 monitors and PMC want to charge me a whole lotta cash to replace it... It seems the original LF Drivers are no longer available so I would need to replace the LF drivers in both speakers. The replacements are a little larger so some enlarging of the opening is necessary. The total cost if done by the good people @ PMC will be approx 600.
However if I knew the make of the LF driver in question (which I don't) I would be very confident in doing the job myself
Does anybody know what driver i need to get or is it possible to upgrade the drivers in both speakers, or are there any other suitable replacements drivers available...?
any help or info would be much appreciated, I really like my TB1's and would love to continue to use them
all the best
hally
Old 7th December 2015, 12:10 AM   #2
R.I.P.
The drivers were made by Vifa.
rgds, sreten.
Old 7th December 2015, 12:23 AM   #3
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
I think it is an M17WG. You might be able to find one eBay. I built a tribute to a TB-1 using Dayton drivers and all active and it sounds very good. Correct amount of damping is critical.
More info here
Low-Cost PMC-inspired TL Monitor with DC130A and DC28F
Old 7th December 2015, 03:29 AM   #4
system7 is offline system7  United Kingdom
system7's Avatar
The Vifa P17WJ-00-08 Woofer seems to be the same chassis (so it'll fit) as the M17WG, which I assume is also a polycone.
Frequency response is identical. Only real difference is the bigger magnet P17WJ is a reflex type Fs 37Hz Qts 0.35 Le 0.55mH, rather than the M17WG Fs 44Hz Qts 0.46 Le 0.8mH. Vas is 34.7L for both.
I shouldn't think that will matter much in a damped line. But others might have a more informed opinion.
Best Regards from Steve in Portsmouth, UK.
Help - PMC TB1 speakers - replacement LF WooferHide this!Advertise here!
Finding replacement LF Driver for 2-way Cabinet intechpc Multi-Way 1 8th April 2013 03:50 PM
Ohm C2's with replacement LF Drivers... mpr2000 Multi-Way 2 17th May 2012 12:26 AM
PMC BB5 speakers help domtweaker Multi-Way 6 14th October 2011 02:36 AM
Genesis 8" Woofer replacement speakers Johnah13 Everything Else 0 27th March 2009 08:02 AM
pmc speakers with volt drivers??? gary_r Multi-Way 1 24th September 2002 01:12 AM
