Need help with crossover - diyAudio
Old 4th December 2015, 02:12 AM   #1
djn is offline djn  United States
djn's Avatar
Default Need help with crossover
Hi all. I can build anything but not really confident with design. I picked up a pair of speakers with good drivers and furniture grade cabs but they sound like crap. They have off the shelf crossovers that allow a huge spike at 3500hz to scream. Here are the data sheets for both drivers. HELP!
sent from cell
File Type: pdf 275-070-dayton-audio-dc28f-8-specifications-46121.pdf (205.9 KB, 25 views)
Old 4th December 2015, 02:48 AM   #2
wintermute's Avatar
Hmmm, just looking at that woofer I would think you are pushing it to crossover higher than about 1.5Khz..... You may get away with around 2Khz... with a serious notch to take out the breakup. The tweeter should be fine with a 2Khz crossover I think.
Do you have baffle dimensions (with speaker positions) and an estimate of distance from the frame to the spider on the woofer? These would help with simulating a crossover.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 4th December 2015, 03:14 AM   #3
djn's Avatar
Hi Tony. What do you mean by baffle dimensions? Is the the dimensions of the front of the cabinet?
Old 4th December 2015, 03:26 AM   #4
AllenB is offline AllenB  Australia
I'd probably look toward 1.9k to a waveguide, or 1.2k to a dome.
Anyway, the breakup peak seems to be accompanied by an overall reduction of output so listening off 0 degrees might help if you must run it that high.
Old 4th December 2015, 04:06 AM   #5
djn's Avatar
No room for a waveguide so I'll have to stick with the dome tweet. What slope should I use to ensure that peak is down enough?
Old 4th December 2015, 04:17 AM   #6
Depending on the point of view, either the peak is relatively harmless because it is only on axis.. or that band is corrupt and should be brought down more than 20dB.
Either way the slope toward the peak is less than 6dB/8ve.
Old 4th December 2015, 04:19 AM   #7
djn's Avatar
Thanks Allen. I'll gin up a crossover tomorrow and post it. I am building these for a friend that does not listen with intent. I doubt he will listen on axis.
Old 4th December 2015, 09:31 AM   #8
wintermute's Avatar
Yes dimensions of the front of the cabinet, and the coordinates for the centres of the drivers on that baffle.
Tony.
Some of my photos
Old 4th December 2015, 05:22 PM   #9
djn's Avatar
The cabinets are 11" wide and 27" tall with the woofer, for the most part, in the vertical center.
Old 4th December 2015, 05:25 PM   #10
djn's Avatar
Here are pix of the speakers.
Help needed to decide: DIY Active Crossover or Passive Crossover? raelman Parts 5 1st October 2014 03:19 PM
BSS active 2-way/3-way crossover, ADS PX Concept 2-way crossover Busyx2 Swap Meet 0 3rd June 2014 07:52 PM
Can you use a digital active crossover to design a passive analog crossover ? RickDangerous Digital Line Level 27 1st April 2013 05:59 AM
Crossover Inductor DCR Values and General Crossover Advice Wayniac Multi-Way 6 15th December 2012 02:59 AM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright ©1999-2016 diyAudio
