Recently my first DIY full range project took a drastic turn when i discovered that I had inadvertently destroyed half of the drivers i bought. (I decided to grind off the 1/4'' tabs
Now instead of having two line arrays that are each 7ft tall, with corresponding arrays of 10'' subs, i am down to 16 2'' drives per side. None of the 10'' drivers where damaged bc they didnt need to have pieces ground down. My current design is to have the 16 2'' drives positioned in the center (vertical line array) with two 10'' drives on the top and 2 10'' drives on the bottom (listening position will be about half way in between the top two and bottom two 10'' drivers so i dont think this will be too much of a problem. Since these speakers will end up being about 7ft tall, I was thinking it mighnt be a good idea to make the 10'' drives into a dual transmission line type of design. Would this even be possible, and is it a good idea. The other option is just to make them all into sealed enclosures. I'm really a novice, so im not quite sure. Any thoughts, comments, suggestions? Negative ones are welcome too. the woofers I'm refering to are thesehttp://www.partsexpress.com/pe/pshow...number=299-721 and since the enclosure for the 2'' array is only about 2.5'' deep, I was planning on making a large narrow C shape for the subs with the 2'' array being in the gap a squared, narrow C would make (side view) btw i am planning on bi-amping with an active XO |
#2 |
frugal-phile(tm)
The Qt on these drivers is fairly high... i'd say you want to look at a TL or an aperiodic enclosure if the TL is too big...
You should also consider mounting the 10s push-push. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
here is something I drew up. Its not to scale, and i havent figured out how im going to have it tapered (should I) yet. But here is the basic premise im thinking about constructing.
full range tl preliminary design Do you think something like this would work well? |
#4 |
frugal-phile(tm)
That will work... you will want to model it ... and i'd put one pr of 10s on the front, and 1 pr on the back....
dave
#6 |
frugal-phile(tm)
like this....
#7 | ||
I recently came across this
#8 |
frugal-phile(tm)
A push-pull situation -- particularily if some attempt is made to couple the drivers -- gives much of the benefit of push-push, tends to average out any non-linearities vis-s-vis the driver moving in vrs out, but also tends to be noisier.
The 2nd comment i'm guessing is about the coupling structure between the drivers... if this is just a dowel wedged inbetween the drivers then i could see that it might come loose on a high excursion sub since it is truly only effective during compression (in an extreme case the connector would just fall out). There are a number of ways of minimizing this, the most thorough scheme is shown in the attached picture. dave A larger picture can be seen from this page. dave
#9 |
Mounting one woofer backwards should be smart. At least as long as the wavelength is much larger than the magnet. The web page is right in that some of the distortion will cancel, however odd harmonics (3rd, 5th, 7th etc) will not cancel, but remain the same. Still an improvement, since the second partial is often strong.
Audio Pro's early subwoofers more or less *required* such a mounting, the active design was very sensitive to a non-linear voice coil inductance. This was taken care of by having two drivers in push-pull. The only downside of the arrangement is some effects towards higher frequencies (1kHz+) and the looks of it. The isobarik mounting has the same distortion canceling benefits. |
#10 | |
frugal-phile(tm)
dave
| Sealed ZRT or sealed ZD5 | sapek | Multi-Way | 2 | 8th May 2009 05:32 PM |
| Sealed box to OB? | mayhem13 | Multi-Way | 11 | 23rd February 2009 02:14 PM |
| Sealed box and ESL | Bazukaz | Planars & Exotics | 29 | 27th November 2005 05:41 PM |
| Sealed midbass vs BR, why not sealed ? | mbon | Multi-Way | 3 | 16th June 2004 10:50 AM |
| Page generated in 0.13342 seconds (81.35% PHP - 18.65% MySQL) with 11 queries |
