As put, it's easy to read more into this than you may have intended. As kaputt has added, the overall system balance can affect the bass perception.
Agreed that perceived tonal balance can shift with a cap change, and harmonics are likely included here. To have the bass extend lower by changing a tweeter cap is still not likely going to happen in a parallel xover. More pronounced bass? Yes- that can occur due to ESR change and tonal balance shift.
Later,
Wolf
