Replacement 6.5 inch woofer for broken SoundCraft Absolute 2 Monitor Speaker - diyAudio
Old 5th November 2015, 02:00 PM   #1
Default Replacement 6.5 inch woofer for broken SoundCraft Absolute 2 Monitor Speaker
Hi
I have a blown woofer and as the speakers were 2nd hand need the cheapest option for a replacement. An Audax HM 170 Z18 was suggested but is far too dear for me - wondered if you could suggest any other same size woofers that I could fit easily as a replacement? 2nd hand is fine. Thanks!
Old 5th November 2015, 04:46 PM   #2
gfiandy is offline gfiandy  United Kingdom
gfiandy's Avatar
Since this driver was made by audax the only one that will fit without modifying the cabinet is the one suggested or the one Audax manufactured for Soundcraft. Have you tried contacting soundcraft to see in they offer a replacement or can recone your existing driver.
Old 5th November 2015, 05:17 PM   #3
are the biwiring jumpers there? i would assume so but it doesn't hurt to ask.
Old 6th November 2015, 08:35 AM   #4
Default soundraft
sorry - I really am a complete novice - biwiring jumpers?
Old 6th November 2015, 08:48 AM   #5
Mooly's Avatar
Bi wiring jumpers. Links that allow the drive units to be electrically separated and driven independently
(not quite sure how that relates to a blown woofer but there you go)
Installing and using LTspice. From beginner to advanced.
Old 6th November 2015, 09:59 AM   #6
giralfino's Avatar
It is not meant to sound insulting, but are you sure the woofer is blown (*), and not that there is another problem? If you don't know where to start for a problem determination, just ask.
That's related, as if they are not there, and the connection from the amp is to the tweeter binding post only, the woofer wouldn't be driven.
Ralf
(*) Blown means shorted voice coil
Old 6th November 2015, 02:06 PM   #7
a local homebrew studio has some of these they concluded the same (blown woofer) when in fact the binding post needed to be tightened (not making proper contact)
(*) blown can also mean open voice coil
Old 6th November 2015, 03:54 PM   #8
thanks all - definitely not insulting. Take your point about whether the woofer is blown - had assumed so because of a slight burning smell from the speaker and the woofer unit after struggling a bit with some low volume output which cut in and out now produces no sound at all. But you're quite right that I haven't determined what the actual problem with the woofer is. The tweeter works fine by the way. There have never been any jumpers present like those shown in the photo above at the back of the cabinet - have just been connecting the speaker cables direct to either pair of contacts to see if it makes any difference.
Old 6th November 2015, 09:19 PM   #9
chrisb is offline chrisb  Canada
Depending on the topology of the XO, it's possible that the burnt smell might be from a damaged component on the board. This is a very common problem with car audio systems which are prone to drastic overdriving. If you've not already done so, pop the woofer out of the cabinet and test it with a 1.5v dry cell battery when disconnected from the XO. At that time you should be able to spot any such smoked XO parts - it's usually pretty obvious.
... time to go, and thanks for the fish.
Old 7th November 2015, 01:46 AM   #10
system7 is offline system7  United Kingdom
system7's Avatar
Stick at it, Andy. It's a biwired speaker:
Soundcraft Spirit Absolute 2
If the nut behind the plug gets loose, you lose the bass output, which happens when you turn the grip thing. The image below is not biwired, but the plugs work the same way. And if you're like me, you don't have any decent tiny spanners anyway. For all that, solder joints shake themselves loose too.
Maybe nothing wrong with the speakers.
Best Regards from Steve Ponsford in Portsmouth, UK.
FS: PHL 3451 3450 Pair of Woofer Bass Midrange Drivers Speaker 101db 10" inch hum4god Swap Meet 3 24th November 2013 02:05 PM
Soundcraft LX7 Replacement parts Alexander Baev Analog Line Level 1 19th August 2013 05:04 PM
2way Studio monitor with 10 inch woofer help rhythmdiy Multi-Way 5 17th December 2008 01:56 PM
Snell replacement 10 inch woofer hollytone22 Multi-Way 5 26th March 2005 07:13 AM
I want to install a new woofer driver into my old broken speaker. S.C Multi-Way 18 25th September 2003 06:40 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
