Phillips Trusonic 206 AXA as Loudspeakers for Acoustic Shows - diyAudio
Old 18th October 2015, 11:40 PM   #1
Default Phillips Trusonic 206 AXA as Loudspeakers for Acoustic Shows
I have a pair of Phillips Trusonic 206 AXA that I accidentally acquired about 30 years ago when I needed speakers and thats all the music store would trade me straight across for. I guess the jokes on them.
For work I'm a singer and acoustic guitarist and I was thinking of using these in shows. They've been around the block and need a little repair on the cones but I was thinking in the right cabinets they might work pretty well. Any thoughts on this usage or what else I could do to put these bad boys back to work?
Thanks,
Sean
Old 18th October 2015, 11:45 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi Sean,
Are these music speakers, or are they home speakers?
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 18th October 2015, 11:46 PM   #3
Pano is offline Pano  United States
Pano's Avatar
Sure, those will work if you aren't trying for deafening levels. They can do deafening in smaller spaces, but you'll eventually blow them up.
If you are just trying to make the voice and guitar carry, sound real and bigger in a moderate space, those would be very good for that.
What size box and what is the crossover like?
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 19th October 2015, 12:57 AM   #4
freddi is offline freddi  United States
freddi's Avatar
could those be rare Stephens speakers? if so then you might use something else and sell them New Page 1
Old 19th October 2015, 03:28 AM   #5
freddi's Avatar
assuming Stephens, they were among the top recommendations for the original Karlson cabinet but at 7.3 cubic foot total, it might be too bulky. You might be able to fetch some good money and buy something cheaper like P-Audio - there's one Stephens 206 axa on Ebay for $1250 - in contrast you can pick up a P-Audio 15" coax new for $199 http://www.loudspeakersplus.com/prod...-AUDIOBM15CXA/
Old 19th October 2015, 04:14 AM   #6
Pano's Avatar
True. Might be better to sell them
If you burn them up in a PA they could be hard to fix.
Old 19th October 2015, 04:13 PM   #7
The speakers are in small oak cabinets that don't look large enough to me so I'm interested in what kind of an enclosure is best. I realize they wouldn't cover a large space as performance monitors but I'm interested in building around a quality sound not audience size...I can always get over the counter monitors for big shows.
Any opinions on size of room these could be effective in?
Thanks so much for the input!
Sean
Old 19th October 2015, 06:42 PM   #8
Pano's Avatar
Driver like these are usually happiest in big cabinets. But the lucky thing is, you don't need big cabinets for what you are doing. Response down to 100Hz will be fine.
Yes, the lowest guitar notes are below that, but it's no big deal. Think of electric guitar amps.
Best test? Hook 'em up and run some live guitar and voice thru them. You'll quickly hear if they are suited.
Volt Loudspeakers vs. Acoustic Elegance ErnieM Multi-Way 11 23rd July 2014 04:45 AM
Stephens Tru-Sonic 206 AXA MCSmith Full Range 28 21st September 2012 06:16 AM
Calculating Acoustic Radiation from apertures driven by Ribbon Loudspeakers thadman Multi-Way 1 22nd October 2009 06:08 PM
One vintage Stephens Trusonic 206-AXA 15" co-axial driver (16 ohm) zobsky Swap Meet 1 1st January 2007 08:02 PM
What to do with these: Trusonic 80FR Joe Kramer Multi-Way 0 29th April 2006 07:01 AM
Copyright 1999-2017 diyAudio
