Old 12th February 2004, 05:27 PM   #1
Default help with hornresponse
I have problem running hornresponse.
I want calculate a basshorn 35/40Hz-300hz with two RCF 15-554 woofers for each horn in a corner position.
But what I get is unreasanable maybe some of you has 10 minutes to try.
I attach T/S parametres.
Giorgio
Old 13th February 2004, 12:51 AM   #2
Not sure if you are implying two drivers in each horn, or one driver each horn in room corners. When you say "unreasonable", what unreasonable results are you getting? If you want best response down around the 35Hz mark, then expect mouth area around 7200cm^2 corner loaded. If this is too large, then tradeoffs can be made in regards low end efficiency and passband ripple.
Do you have these drivers on hand, or intend to purchase them? For home use they would seem to be a bit overkill, and their Fs could be a touch low for a horn. Could very well be better off with a 12" design if space is a problem. How loud do you want it?
Cheers
Old 13th February 2004, 08:05 AM   #3
I'm implying two drivers each horn. I get only S1 and S2 not length. In order to reduce mouth size I can accept 40Hz response.
I have them so I'm triyng to use them. I expect loud 102-105dB.
Giorgio
Old 13th February 2004, 11:26 AM   #4
Hmmmm, they don't like to go down all that low in a horn without a fight....... seem to need small throat area to get any low end - should be loud though!
Try this:
Cheers
Old 13th February 2004, 11:27 AM   #5
....and the input parameters to get it:
Old 13th February 2004, 12:07 PM   #6
Banned
Send a message via MSN to SkinnyBoy
umm... SD of 1700cm^2??? two drivers? yeah?? compressed to 400cm^2 I don't think so.. lol
Old 14th February 2004, 06:23 AM   #7
mikee12345's Avatar
thats a moderately high compression ratio,which isnt the best for unknown speakers
edit-1700cm for TWO
actualy its only ~2:1 each..
skinnyboy!
Old 14th February 2004, 06:37 AM   #8
edit-1700cm for TWO
Actually is more like 4:1, which is reasonably high for bass horn, but this particular driver is a pretty good one and should be able to handle it ok. If these horns are mainly used in a domestic environment, then the volume level in the throat should be low enough not to cause problems.
Cheers
Old 14th February 2004, 09:26 AM   #9
VRC 250.00 rear compression chamber volume 250 litres?
Giorgio
Old 14th February 2004, 12:40 PM   #10
Yep, smaller volume gives very peaky response down low - may be able to get away with half this, though.
Don't really think this driver is overly suited to horn use, but could be done. These drivers were very common in bass reflex EAW boxes.
Cheers
HornResponse Maximum SPL bubblersound Subwoofers 3 21st June 2009 03:07 PM
comment on hornresponse sim Jimmy D. Multi-Way 2 9th November 2008 07:34 PM
altec 515 and hornresponse patriz Multi-Way 3 21st August 2007 11:14 AM
phase rotation with hornresponse patriz Subwoofers 2 13th June 2006 10:59 AM
Page generated in 0.11873 seconds (79.64% PHP - 20.36% MySQL) with 11 queries
