I have purchased a pair of Eton 8-800/37 woofers and some MB Quart MCD 25 tweeters.
I plan on using a similar version of the Eton 8.1 x-over, here's the link http://www.eton-gmbh.de/dlstream.php...e1771eec176c51 My question is when Eton recommends the gauges for the inductors, do you think those are minimum gauges or they're the exact gauges you need to use for the x-over. Also what's MKP stand for? And the resistors can all be metal oxide right? Or should I use metal film? The bi-polar cap needs to be bi-polar? I'm asking because I have a bunch of non-polar caps. |
#2 |
No one knows whether the inductors wire diameters Eton recommends, are minimum gauges or they're the exact gauges you need to use for the x-over?
The link again is http://www.eton-gmbh.de/dlstream.php...e1771eec176c51 |
#3 |
L1 can be any gauge, due to R1, if its DCR is significant subtract it from R1.
L2 and L3 I'd treat as recommended gauges. IMO : L3 being a size smaller gauge will have little effect, larger gauge pointless. IMO : L2 will have a higher DCR than L3 and a size larger gauge makes some sense. So IMO using a size smaller gauges for L1 and L3 will be OK. L2 I'd regard as minimum recommended gauge. MKP is a manufacturer of capacitors, implies a quality level. In its position the bi-polar capacitor will have little effect on sound quality, which is why bi-polar is specified. Non-polar will be better. |
#4 |
Thanks sreten,
I forgot to mention that I only have 1 mm or 2 mm gauge diameter wire for inductors. So all the wire I have is larger than one of the recommended diameters. I'd like to use the larger gauge wire for L1,2,3 if it helps make the speaker sound better. Also I didn't mention that I have no bi-polar caps, but I have a bunch of non-polar caps. That's why I was asking. As for the MKP capacitor, I'm not sure my caps are as good and I don't know how I can find out. But they are Bennic caps and less expensive. |
#5 |
Also I was told to change the value of the tweeter capacitor from 4.7 uF to 9.0 uF. Wouldn't this change the x-over point drametically and wouldn't I also have to change the tweeter inductor value (L3)?
I suspect that the 9.0 uF recommendation might be a single cap with a 6 db/octive roll-off, no? It's a different tweeter than the Eton 25 SD, I will use a MB Quart MCD 25, also 8 ohm. |
#6 | |
frequency (less than you appear to think it will) with L3 the same. Presumably the different Q is intentional. 2) I can't see how R2 and R3 are the same for a different tweeter, unless they fortuitously have similar parameters. |
#7 | |
#8 |
One last thing (I hope).
I only have the capacitors to make a 14.9 uF non-polar cap for the x-over. Should I just buy a 15 uF polar cap or this doesn't make a big difference? |
#9 | |
You only use bi-polar to save cash in non-critical positions, or a bypassed bi-polar when you can't afford a non-polar. |
#10 |
Yes, but they're non-polar and I can only make 14.9 uF instead of 15 uF. Should I buy a non-polar of polar cap that's 15 uF. Does the .1 uF make that much difference? They're 5% caps I believe.
| Kit Confusion! | deadparrot | Chip Amps | 6 | 28th May 2009 08:52 PM |
| mox confusion | cowanrg | Solid State | 10 | 9th August 2005 11:11 AM |
| More(l) confusion | mr_push_pull | Multi-Way | 2 | 29th May 2005 04:54 PM |
| Speaker with Eton Er4,Eton 11-581 and T&P C79 ?? | guru | Multi-Way | 2 | 7th May 2004 09:36 PM |
| I2S confusion | MWP | Digital Source | 2 | 9th November 2002 10:36 AM |
| Page generated in 0.10734 seconds (86.16% PHP - 13.84% MySQL) with 10 queries |
