Noob question about DIY speakers and crossovers - diyAudio
Old 7th October 2015, 04:57 PM   #1
Default Noob question about DIY speakers and crossovers
I have a quick question and I wasn't sure which category to post in. When someone designs a crossover what is the reason, for example, to use 2 = 12ohm resistors in parrallel to achieve 6ohm instead of just using a 6ohm resistor. I have seen this in several of the DIY speaker designs out there. Thank you for your time.
Chuck
Old 7th October 2015, 05:22 PM   #2
Mooly's Avatar
The first thing that comes to mind is that it allows a lower wattage part to be used.
e.g. 6 ohms and say 6 volts across that resistor needs a 6 watt part (V squared divided by R). Using 12 ohms allows a 3 watt part to be used.
Old 7th October 2015, 05:28 PM   #3
wg_ski is online now wg_ski  United States
And the case temperatures will be lower, with less tendency to cook the board and surrounding components.
Old 7th October 2015, 06:11 PM   #4
Einric is offline Einric  United States
Einric's Avatar
Also if you need an oddball value, you can parallel 2 different value resistors and gain the extra dissipation while also hitting your oddball target value.
Old 7th October 2015, 08:47 PM   #5
So it is not done to necessarily have an impact on sound, but more to achieve a target value or reduce heat. That is what I kind of assumed but just wanted to make sure. Thank you all for such quick replies.
total diy noob, need to understand how to match speakers. iggy18 Multi-Way 19 11th July 2012 11:40 PM
DIY speakers using Linn active crossovers? 100decibels Multi-Way 3 4th June 2012 04:06 PM
noob question, planar speakers vs ESL on bass hello im sean Planars & Exotics 10 15th May 2012 12:23 PM
Question about front horn speakers and passive crossovers Bill poster Multi-Way 2 30th September 2010 06:46 PM
Filter noob Question Re Diy headphone. setmenu Headphone Systems 2 8th July 2002 08:17 PM
Copyright 1999-2017 diyAudio
