I'm looking at making some Jordan JX92 enclosures in the next few months here with a 1 1/4" granite front baffle. I was curious of whether I should just flush mount the driver or leave a set on contentric rings surrounding the driver. While I can't do that 45 degree cut like on the Pass Labs Rushmore speakers, but I could do a number of contentric circles creating a simliar effect, but I'm not sure which would be best "sound wise".
#2 |
what-ever gives the smoothest transition from spkr to baffle, - flush mount it
#3 |
Do you smell smoke?
Don't ask me to help you move them!
Peace |
#4 |
I would suggest a flush mount.
#5 |
Hi Moses,
A 1.25" thick baffle with cover up a large amount of the side perimeter of the cone, causing reflections to the back of the cone which you will hear. Have you considered surface mountng to a stronger baffle material like 0.5" Aluminum? From my experience, any front baffle obstruction or waveguide creates frequency fluctuations from diffraction and also reduces the width of the sweet spot. |
#6 |
He's right about the baffle causing problems with the rear of the driver. I would at least baffle or scallop the rear of the driver opening to improve air flow. And I recommend flush mounting.
It's a neat idea, how are you machining the granite? |
#7 |
Then flush mount it is. I'll see about making a series of cuts behind the driver to allow for better airflow. As for cutting I'll have the granite guys next door cut it to size, the opening for driver I'll make with a custom made jig and a 4" angle grinder with a diamond blade. Not having the contentric circles on front does save me a lot of polishing time which is good thing.
#8 |
diyAudio Editor
yeah, concentric rings would be the worst..
| Granite Baffles ? | ronzeman | Multi-Way | 15 | 23rd August 2008 05:49 AM |
| am I crazy? granite for OB baffle | sqlkev | Multi-Way | 11 | 3rd October 2007 12:40 AM |
| Is there something wrong with small front baffles on subwoofers? | The Paulinator | Subwoofers | 9 | 27th March 2006 02:57 AM |
| Granite tiles | ivegotmono | Tubes / Valves | 3 | 9th February 2006 10:35 PM |
| granite lined sub? | speekergeek | Subwoofers | 5 | 10th November 2003 12:58 AM |
| Page generated in 0.08986 seconds (77.69% PHP - 22.31% MySQL) with 10 queries |
