Visaton system - what is wrong here? - diyAudio
Old 20th September 2015, 08:09 PM   #1
mcl2k6 is offline mcl2k6  Europe
mcl2k6's Avatar
Default Visaton system - what is wrong here?
Hello all,
I started to do some ARTA measurements with my homebrew speaker system I've presented here in another thread. After a couple of tweaks, I managed to get the higher frequency response pretty even, but what I continue to see is a big dip at around 125Hz. I am wondering, what am I doing wrong?
The system is a two-way, W170-S woofer, and a SC10N as tweeter, crossed over at 2kHz, see the xover design, Visaton boxsim FR, phase, and ARTA measurement files attached.
The mic is a Panasonic WM61-B, with the attached calibration file.
The loudspeaker box has got around 35liters, and currently there is no phono-absorbant material in it.
What I don't understand is where am I getting that big dip at 125Hz from? Is it some due to the W170S response, or am I missing something?
Old 20th September 2015, 09:01 PM   #2
giralfino's Avatar
Room reflection, usually the floor: at that frequency the path driver-mic is anti-phase with the path driver-floor-mic. If you want to compare simulation with measure you should perform a gated measure.
Ralf
Old 20th September 2015, 09:33 PM   #3
mcl2k6's Avatar
Ralf
But that's what I am doing. Single gated FR measurement.
Just measured, the woofer is at 105cm from the floor, thre reflex port is at 60cm or so, and the speaker was at ~105cm too.
Old 20th September 2015, 09:54 PM   #4
mcl2k6's Avatar
Actually, this is (green curve) what I will be getting, if I raise the woofer to 180cm:
Old 20th September 2015, 10:19 PM   #5
giralfino's Avatar
Are you sure you are gating? It's not what I expect to see, and there should be a horizontal yellow line indicating the minimum valid frequency. How long is your gate?
Ralf
Old 20th September 2015, 10:22 PM   #6
mcl2k6's Avatar
Ralf
I'm using the full length of the recorded stream. Should I do something else?
Old 20th September 2015, 11:33 PM   #7
Dissi is offline Dissi  Switzerland
Wrong is when you change a decent crossover to the worse, just because measurements with a noncalibrated microphone tell you to do so!
Sorry for that, but I really liked the previous version of your xo. OK, crossing the SC10N lower than 2 kHz is keen, but everything else looked very nice IMO. Now I'm a little bit shocked to see what you have done to the tweeter. That bump at 2-4 kHz and the corresponding impedance minimum can't be right. Attached is a simulation of the previous version I'm referring to.
Those cheap microphone capsules vary significantly in frequency response, and they also depend on details of mounting (prominent, flush or recessed). Hence it's very unlikely that a general microphone correction file does provide the accuracy needed to rely on.
Back to the topic. The dip at 125 Hz also could be caused by a standing wave in the fully undamped cabinet. The quarter wave length of 125 Hz is about 70 cm, which corresponds more or less to the height of your cabinet.
Old 21st September 2015, 12:30 AM   #8
AllenB is offline AllenB  Australia
Placing the woofer at half the room height and putting the mic close by will get you the lowest possible valid frequency. That's it, yes you should cut the stream there, the floor and ceiling bounce should be obvious. Of course you can't have the mic too close..
After that it probably matters less. Partly because the bass response is fairly predictable and could be worked out from nearfield measurements. Partly because these frequencies shouldn't necessarily be worked out with equalisation so much as by navigating and treating the room response.
Old 21st September 2015, 06:29 AM   #9
mcl2k6's Avatar
You are absolutely right over here! Today morning I had listened the same music as yesterday night, and the speaker is shouting pretty much in the midrange. It seems that the Visaton sim was right. Your results give the same results (rather flat FR), so I think that today I'll be reverting to the old design. I was thinking to open up the midrange a little bit though.
BTW, what software is that you are using?
Dunno about this, some chaps on different forums usually praise the WM61 capsules.
Yep, that could be. I'll have to try to use some phono absorbent material. Shall I fill the cabinet with a certain amount, or would it be enough to line the walls with?
Old 21st September 2015, 08:58 AM   #10
giralfino's Avatar
So you are not gating. See here for an how-to: http://audio.claub.net/tutorials/FR%...ing%20ARTA.pdf
Ralf
Boxsim Full System Design from Visaton - Free PB2 Multi-Way 16 22nd March 2015 06:52 AM
Small HTIB System/Computer System Review form109 Multi-Way 0 19th November 2009 02:59 AM
Wrong Voltage / current on BoZ... or Wrong Measuring ? gionag Pass Labs 8 14th May 2008 11:24 AM
"Visaton - is it worth?" or... "Share your Visaton experience" mr_push_pull Multi-Way 10 7th August 2004 06:18 PM
Visaton shadow Multi-Way 6 16th June 2002 09:27 AM
Copyright 1999-2017 diyAudio
