I'm working on a design the uses the Morel MDT-39 tweeter. Its dome extends about 1/8" above the housing. I'd like to use a sock to cover the speaker. I'm thinking about using an arch of screen wire to protect the dome. But I am concerned about diffraction problems caused by the screen. Anyone done this? Anyone have thoughts on other solutions?
This space for rent. |
#2 | |
http://www.dynaudiousa.com/mainmenu/...temptation.pdf another one (Accuton Tweeter): http://www.cvd-diamond.com/tfdipo/frames_d.htm Regards Charles |
#3 |
cheers TC
we all have problems only some people have more than most.... long live the Magyar (Hungarians) in the world! |
#4 |
simply recess the tweeter by an extra 1/8" or so and add a bevel to the recess cutout.
#5 |
Ah. sreten, I like that answer. I'll try that first. Have you any empirically based bevel types/angles to recomend?
#6 |
Ok ill second the reply of qwad, I have MDT30's and unfortunatly then dome got completely squashed in I mean completely looked like a focal tweet.
Either way I used the not very stylish but works technique of sucking out the dome a la bouche. Either way no dmg done to the dome, no effect on the sound = no worries. Remember these domes are made of soft fabric out clothes dont die when we move in them so why should a soft dome. The shape of these is maintained I think anyway by the profile of the thing, Ie the circular nature.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#7 |
OK 5th, I believe y'all, and appreciate the suggestions, but I want to put a sock on it. Cloth stretched over the domes can't be a good thing can it?
#8 | |
I'd suggest a plane 60 angle with a little rounding / sanding of the outside edge. P.S. also make sure the bass units at full mechanical Xmax do not touch the sock, a mistake I made with a driver with a forward roll surround, the occasional buzzing with grilles on had me perplexed. |
#9 |
Many thanks, especially for that last bit. It would never have occurred to me.
| 2nd Order Dome SUB | djcl.ear | Subwoofers | 7 | 24th June 2009 07:49 PM |
| MTM Horn vs Dome for the T | Robh3606 | Multi-Way | 0 | 20th August 2007 03:55 AM |
| speaker protection (OR) overload protection | myanmar | Solid State | 7 | 13th July 2006 08:21 AM |
| WTB Yamaha 690 Dome Mid | dc270 | Swap Meet | 2 | 13th February 2006 03:56 PM |
| Page generated in 0.09508 seconds (85.41% PHP - 14.59% MySQL) with 10 queries |
