Point to point crossover advice - diyAudio
Old 5th September 2015, 02:29 PM   #1
Thumbs up Point to point crossover advice
Hiya.
I'm about to rebuild the Xovers on my TDL Studio 3s and have got a new set of caps, inductors and resistors, all of the original values, just better quality.
My plan was to point to point the components using a silver based solder (which is a bit tricky to work with but I'm getting used to it.)
I have read a suggestion of mounting it on an MDF board but wondered if this was the best thing to use as a base. Would a hard wood of some sort be better/more dense/have less resonance?
I then hope to mount the x over outside the speaker.
Any thoughts/tips or more importantly things I shouldn't do?!
Thanks in advance for your help
Old 5th September 2015, 02:45 PM   #2
doctordata's Avatar
Some solder terminal strips make the job much easier .
MDF is fine .
Attached my Tannoy 3839 crossovers .
Cheers ,
Rens
If you measure, you know; if you guess, you don't
Old 5th September 2015, 02:47 PM   #3
Nice one.
And thanks for the swift response!
Old 5th September 2015, 03:01 PM   #4
doctordata's Avatar
Originally Posted by irishiranian View Post
Nice one.
Forgot to mention that all the components are glued to the MDF and to each other where needed with contact cement to prevent "rattling". and keep at least 10cm distance between the inductors so they won't influence each other .
Cheers ,
Rens
Old 5th September 2015, 06:35 PM   #5
Cool. There's only one inductor per speaker. Do I need to worry about positioning of the caps and resistors in relation to the inductor too?
Old 7th September 2015, 08:02 AM   #6
AllenB is offline AllenB  Australia
Not really. They could interact slightly, but so could the loops formed by the connecting wires with widely spaced components. Mostly no though.
Point 2 Point (no PCB) for TDA7293, TDA7294, TDA7295, TDA7296. danielwritesbac Chip Amps 152 28th January 2016 08:17 AM
Combination of PCB and point to point wiring a bad idea? dacster Tubes / Valves 14 6th September 2015 01:57 AM
Lots of craziness (weird noises and osc) happening in point to point 5W EL84 Amp 777funk Instruments and Amps 17 2nd March 2014 07:20 PM
need 2 way crossover point advice dc1005 Multi-Way 1 30th September 2011 12:13 AM
Point to point crossover soldering Ilianh Multi-Way 9 24th December 2002 05:14 AM
Copyright 1999-2017 diyAudio
