Drivers from vintage '64 Wharfedale W90 - diyAudio
Old 18th August 2015, 02:15 PM   #1
OTLguy is offline OTLguy  United States
Default Drivers from vintage '64 Wharfedale W90
Greetings, Great forum by the way--great work contained within. My question is aimed at the Wharfie experts out there with knowledge of the W90 speaker and all its versions.
My question specifically, did Wharfedale W90 speakers ever utilize tweeters that were NOT the 11/15 Ohm impedance? There were 2/3 Ohm versions produced during the same period.
Old 19th August 2015, 02:28 AM   #2
devilsindetails's Avatar
I've owned several sets of the W90s. W70s and W60s.....
The Ferrite Magnet Super 3 Tweeters in most of mine were of the 8 ohm nominal variety with actual DCR usually in the range of 6.5 ohms which is about par for the course.
I've found that the complement of tweeters in the W90s often varied greatly in terms of design....some fitted with Alnico versions other with Ferrite versions and sometimes even mixed between the two versions depending on the production date and run.
The Super 3s employed in the W70 and W60 are exactly the same as those found in the W90s so if you're looking for spare ones you needn't think they were exclusive to the W90 design.
The 11/16 ohm versions I've seen were found in the earliest iterations of the W60 to W90 and have been exclusively of AlniCO construction.
I've never come across 2/3 ohm versions.
"A problem left to itself dries up or goes rotten. But fertilize a problem with a solution--you'll hatch out dozens." (N.F.Simpson)
Old 19th August 2015, 11:44 AM   #3
Thank you for the info. I'm looking for vintage early 60s Wharfedale Super 3 tweeters of the 10/15 ohm impedence to pair with my Super 8 full range of the same impedance. Ceramic or AlNiCo magnets make no difference to me. Thanks again for your helpful information.
Wharfedale W90 desperateaudio Multi-Way 5 3rd September 2013 02:08 AM
Wharfedale W90 Crossover Help jodyscott Multi-Way 12 7th July 2013 09:41 PM
Philips FR drivers/ EV fullrange drivers/ Vintage Wharfedale x/overs devilsindetails Swap Meet 2 28th November 2011 12:09 AM
Vintage Wharfedale drivers argonrepublic Multi-Way 1 19th June 2005 04:14 PM
WTS Vintage - Wharfedale '60 Deagle50ae Swap Meet 0 11th December 2004 10:07 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
