B&W 803 for F.A.S.T.?
Old 18th August 2015, 03:38 AM   #1
microdub is offline microdub  Australia
Default B&W 803 for F.A.S.T.?
So for sale locally is a pair of B&W 803 matrix S2 speakers which are missing the tweeters and with one mid range shagged. The other mid works and all 4 bass drivers and cabinet are fine. They are also cheap.
So, is this the sort of thing you could convert into a fast? The speakers are bi-amp-able so bass drivers run off their own crossover.
I guess you'd use a 3-6 or so full range for mids and highs?
You could modify the mid cab volume to suit the full range.
what do you think?
Old 18th August 2015, 04:42 AM   #2
hollowboy is offline hollowboy  Australia
It sounds very fast FAST capable. I made a pair last year with this layout (4" plus two 6.5"). The 4" was a high Qts TV speaker, in a short, fully stuffed line which vented to the rear.
Caveats:
Given that the B&W is 20 years old and thrashed, I'd hope they are VERY cheap, or that you can inspect thoroughly before you buy.
They are finished in black wood-grain vinyl, right? I'd recommend tearing that off and re-skinning them.
The specs may have changed from age / abuse. If the magnets are a bit weak, the port tuning might be off.
This edit signature thingy is seriously hard to find
B&W 803 for F.A.S.T.?Hide this!Advertise here!
B&W 803-inspired Zaph ZRT Build rulzahl Multi-Way 6 23rd June 2015 06:07 AM
Help needed with vintage B&W Matrix 803 yairf Multi-Way 0 6th February 2013 07:43 PM
What to do with 803's thevoice Tubes / Valves 6 8th October 2006 11:55 PM
Bedini BA-803 Schematics??? Zero Cool Solid State 0 13th October 2004 03:35 PM
B&W Matrix 803, 804, or 805 Tweeters HELP boisehomes Multi-Way 0 8th February 2004 10:58 PM
Copyright ©1999-2017 diyAudio
