Pics baby Fostex FE83 2-inch driver on large Yuichi horn
Old 16th August 2015, 09:38 AM   #1
atilsley is offline atilsley  Australia
Default Pics baby Fostex FE83 2-inch driver on large Yuichi horn
For fun, I swapped out my Faital Pro HF200 drivers and added in the baby 2 inch Fostex FE83 paper cones I had lying around.
The existing system consists of:
Tweeter: Faital Pro one inch CD with matching FP alloy horn
Mid horn: Azura 340 Hz horn with Faital Pro HF200 CD
Mid bass: 12 inch Kappalite in sealed birch box (hidden behind the large Walnut cabs)
Bass: Bill Fitzmaurice Table Tuba, with 8 inch Tang Band driver. (To be veneered.)
Amps: six channel Holton Precision audio power amp, plus separate pro amp for sub
Xover: MiniDSP 2x8
Source: Spotify, I-phone, Pure docting station, digital to xover.
Great sound, very 'big', and wide/high sound stage.
With the baby Fostex drivers, the sound is more laid back, more 'analogue.' I'm very impressed...and with tuning, I think these would/could make for a great start into horns. We're comparing $100 of drivers vs $600.
A fun project.
Old 16th August 2015, 09:43 AM   #2
A few more pics, including CNC'd stands in Walnut ply. CNC routered hole for Faital Pro tweeter.
Old 16th August 2015, 11:24 AM   #3
Scott L is offline Scott L  United States
Default excellent !
Now, this is what I call a great idea !
Taking advantage of the entire flare rate !
I have often wondered why [very] large horns are constructed with only
2 inch throats (?)
Old 16th August 2015, 04:10 PM   #4
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Andrew, it is a 3" driver (80mm).
A good use for the driver. What about trying FF85wk?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th August 2015, 10:47 PM   #5
dave
Thanks Dave....I had the FF83 spare, so they got a look in initially.
I realised it was 3 inch after I posted...interetsinglly, the size of the actual cone is exactly 50mm (2 inches)...that's how I made the mistake.
With the FF85wk, what would you suggest are the main advantages...the power rating is ismilar...but seems to have more xmas. The high freq range is impressive...but isn't that academic as I'm only using the bandwidth of 700Hz to 3,500Hz? I guess if someone wanted to build a two way, then this drver owuld be a good contender.
Kind regards.
Andrew
Old 16th August 2015, 10:51 PM   #6
frugal-phile(tm)
planet10's Avatar
The main advantage … at least in a box/baffle … is that it sounds better. They get really good when treated.
In a box they can reach about an octave lower than the FE83.
dave
Old 16th August 2015, 10:56 PM   #7
OK, thanks Dave...that's very intresting.
Do you hear from many folk about using paper cones in horns, isntead of CD's (generally speaking)? The difference in price, for example, is huge.
Old 16th August 2015, 10:58 PM   #8
frugal-phile(tm)
planet10's Avatar
I don't pay much attention to front-loaded horns, but i have heard about many using cones, and domes horn loaded.
dave
Old 16th August 2015, 11:07 PM   #9
OK, thanks again.
All the best.
Old 17th August 2015, 02:51 AM   #10
Bare is offline Bare  Canada
Andrew
Hardly a mistake.
A 2" diameter Cone is a 2" Speaker, even (especially IMO) in Aus.
Complete unadulterated 'Brochure Babbles'.. no more .. no less.
Why not add in the Bezel diameter while at it ? Or the box it came in.
Reads too much like a braggart in a Bar telling a hapless woman about the size of his 'apparatus'.
Think she might Laugh when faced with the reality?
Pics baby Fostex FE83 2-inch driver on large Yuichi hornHide this!Advertise here!
Pics DIY Yuichi 290Hz Wood Horn atilsley Multi-Way 99 6th January 2016 01:58 AM
Fostex FE83 - Nagaoka F-81 or not rasputin1 Full Range 14 12th February 2015 08:15 PM
Pics new DIY Yuichi and large 'Altec' Bass Horn atilsley Multi-Way 37 10th September 2014 09:33 PM
Pics of 3-inch Fostex in big Traxtrix horn atilsley Full Range 4 25th May 2009 05:54 PM
Large backloaded Fostex horn??? Circlomanen Full Range 13 24th April 2005 11:21 AM
Copyright ©1999-2017 diyAudio
