Measured by Dr Boar: Beyma CP21/F - diyAudio
Old 12th August 2015, 09:02 PM   #1
DrBoar is offline DrBoar  Sweden
DrBoar's Avatar
Default Measured by Dr Boar: Beyma CP21/F
I have a pair of old second hand CP21/F Beymas graphs looks like this (linked in Europe Audio)
The new shiny one and the corresponding graph from Beymas home page.
My own measurements:
Using XTZ room analyzer II. Driver on carpet facing up with mic 10 cm in front of driver.
Using Omnimic with 1 m measurements distance and the driver at the end of a long spirit level so there is no baffle loading. The setup:
The results using both a 5 dB and 2 dB resolution.
I think my measurements using both different systems and setups are consistent with the Beyma graphs.
The shelf 2-4 kHz is there, as is the peak around 8 kHz and the squiggle at about 13 kHz and finally the drop just below 20 kHz.
I intend to do distortion (105 & 95 dB perhaps) and time domain measurements. But I need to get better earplugs to protect my hearing and also do the measurements when my wife is out of the house.
Regarding my measurements there is consistent dip below 4 kHz compared to Beymas measurements. Do the horn actually benefit from a baffle? Not that I intend to cross it lower than 4 kHz.
Acoustic Gain From Using Adjacent Dr dr chienmort Full Range 3 24th September 2014 02:49 PM
Tqwt with Beyma BEYMA 12XA30/Nd simulation sladdbarn Multi-Way 11 18th May 2013 03:58 PM
Beyma CP21/F Sjef Multi-Way 7 29th December 2004 07:54 AM
Calling Dr. Fletcher! Dr. Munson! Apparent 20 dB Discrepancy! kelticwizard Multi-Way 10 18th November 2004 01:59 PM
Self measured T/S bhg41088 Multi-Way 10 14th May 2004 12:09 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
