Seas 22TFF H1280 Tweeter - diyAudio
Old 12th August 2015, 02:13 PM   #1
keilau is offline keilau  United States
Default Seas 22TFF H1280 Tweeter
https://www.madisoundspeakerstore.co...22tff-tweeter/
H1280-06 22TFF
Looking for the FRD/ZMA files for this Seas 22TFF H1280 Tweeter, measured or converted from the manufacturer's curves. Thank you for your help.
Old 13th August 2015, 01:22 AM   #2
system7 is offline system7  United Kingdom
Sin Bin
Keilau, I wonder why you're not considering the similar metal dome version SEAS 22TAF/G? I'm sure Spendor have their reasons for using the 22TFF, but I can't think of a good one.
Everybody really likes the SEAS 22TAF/G. Even Joachim Gerhard:
Any filter that works with the metal 22TAF/G is going to work with the soft dome 22TFF IMO, being so similar. But the metal dome is going to like a 7.5R and 0.68uF Zobel IMO. Just sounds smoother.
DIY-Loudspeakers
Can't help you with the FRD and ZMA files. But I don't think it's that hard.
Old 13th August 2015, 02:27 AM   #3
re:"reasons for using the 22TFF" - they're cheap, have wide dispersion, & sound good, relatively easy to cross over.
cons - don't like too much power at the low end
currently using these in my main system, & have no desire to change, even though I have more expensive tweeters available...
cheers,
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 13th August 2015, 02:38 AM   #4
DIY-Loudspeakers.
I am looking to upgrade the tweeters on 3 Wharfedale M-138 and M-128. I want the replacement to fit the exsisting recess hole. Either of them should work for me. The TFF is cheaper and I don't need to worry about taming the high frequency resonance. It is not a final decision until I order.
I have created a few FRD/ZMA from printed curves. But I don't really enjoy the process.
Roman Bednarek used the SEAS 22TAF/G for his Microbe SE project, but there is no FRD/ZMA for the tweeter at his Audiofiles page.
Old 15th August 2015, 08:39 PM   #5
I created the FRD/ZMA files from the manufacturer's curve for Seas 22TFF H1280.
It should be very easy to modify for 22TAF/G.
Old 16th August 2015, 08:48 AM   #6
Zuhl is offline Zuhl  England
Zuhl's Avatar
It's no surprise you prefer them to more expensive tweeters. I feel the same about my 22TAF/Gs.
One good thing about music, when it hits you, you feel no pain - Bob Marley
Old 17th August 2015, 04:43 AM   #7
Do you mind to share your experience with the Seas?
I grew up with the like of Audax 12x9D25 and Seas H107 soft domes. They were very popular in the 1970-80 and were used in many highly respected boxes including the Spica TC50, Black Dahlia and the Larry Hughes bookshelf DIY that I built. I cannot image paying much more than I paid then, adjusted for inflation.
The Seas 22TFF is on its way. I have not been able to tried that yet.
Old 17th August 2015, 06:18 AM   #8
Zuhl's Avatar
Here's my design using the 22TAF/G. There have been some minor x/o revisions since then. A Classical Three-Way Design
The sound is very clean. By that I mean there are none of the fizzy, gritty, mushy, metallic and/or other various adjectives associated with treble sounds. It disappears and all you have left is the music
Seas waveguide tweeter? otto88 Multi-Way 8 23rd July 2008 02:37 AM
Most non-sibilant Seas tweeter D.A.R.R.Y.L. Multi-Way 13 29th September 2006 01:59 PM
Which Seas tweeter 2 choose.. ? CBC Multi-Way 8 6th April 2005 09:05 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
