#11 | |
In these terms your article does make sense in trying to debunk one myth, which is fair enough, but these terms were not given. But a right doesn't justify a wrong, and talk of infinite transient response etc is entirely misleading, and only possibly applicable to tweeters or the like. The simple fact you appear to be alluding to is many subwoofers have an intrinsic bandwidth, and any attempt to use them outside this bandwidth, or lack of consideration of this bandwidth, will impair the resultant frequency response and by definition transient response. Its extremely true a driver with a bandwidth far exceeding its required range will perform within range, converting this to transient response arguements is pointless and misleading. Finally it is simply not true the inductance is the only indicator of transient response capabability, but this is entirely irrelevant for subwoofers. Also I'm not aware of the arguement you are trying to debunk, but it seems to allude to efficiency, which like it or not, is nearly always associated with good transient response, high efficiency = good dynamics, which is most of the time true. |
#12 | ||||||
Sreten posted:
Note that many times manufacturers - especially in the prosound and some parts of the high end world - will "fudge" bandwidth by publishing highly smoothed response curves. What you see is not only the bandwidth of the driver, but it's often artifically extended by cone breakup. Smoothing out cone breakup can make the driver appear to have more bandwidth than it really does. Quote:
I think many times people associate dynamic drivers/light drivers as "fast" for a couple of reasons: 1. They tend to often have hotter top ends than low ends (biased towards the higher end of the spectrum) which can make it sound wider in frequency response than it really is. 2. Often the inductance of high efficiency drivers is low, because voice coils are heavy so they are wound as short and small as possible. It's the search for high efficiency (low moving mass) that lowers the inductance, and as a result bandwidth is increased. It's not because of the efficiency itself, but an side-effect of the need for low mass that gets you the low inductance. Thanks, Dan Wiggins Adire Audio |
#13 |
Hi DW,
I don't really want to go into whats relevant as an arguement. You are correct the transient response arguement is only a transform away from the bandwidth arguement, but I'd suggest for your less than well informed types the article is supposedly intended for the bandwidth version is a lot more straightforward. My point about the bandwidth of subwoofers is that most do have the bandwidth required, except for the silly ones. I quite agree dynamics isn't the same as transient response but again I'd suggest your misleading your less than well informed types with an arguement they will misunderstand. Finally a voice coil has an effective mass. So does a driver cone, but importantly this reduces with frequency, the high frequency roll-off is simplistically defined as when these are equal. So the cone / voice coil interface defines hf bandwidth and transient response, not the simple voicecoil inductance, |
| HiVi B3s voice coil inductance - How to calculate? | chylld | Full Range | 2 | 15th January 2009 07:10 PM |
| Single Voice Coil Vs Double Voice Coil Subwoofer | Workhorse | Car Audio | 6 | 12th April 2007 06:36 AM |
| FE127E voice coil inductance for Zobel calculation | arjscott | Full Range | 3 | 7th February 2007 01:42 AM |
| Measuring voice-coil self-inductance | Klimon | Multi-Way | 4 | 19th November 2006 12:23 PM |
| Voice Coil Inductance (Le) and Transient Responce | amo | Multi-Way | 11 | 8th June 2003 07:45 AM |
| Page generated in 0.12411 seconds (77.70% PHP - 22.30% MySQL) with 10 queries |
