I'm not getting your point here, freddi!
4.25" Round 10 oz 8 ohm 3/4" V Phenolic Ring Tweeter
It's the modern Acoustic Research cone tweeter replacement, isn't it? You can get it at Madisound and Parts Express too. The Monacor HT22-8 is not dissimilar.
in the US they are imported under the Dynavox name - I'm not sure how to use the 10oz magnet model as it appears to have a bump on the bottom and even with 1uF highpass, wants to corner around 3K - how does one successfully use one with a high crossover?
http://www.dynavox.com/4.25inch-Round-6-oz-8-ohm-20mm-VC-Phenolic-Ring-Tweeter
I had a pair of AR4x when they came out
With one of these bad boys:in the US they are imported under the Dynavox name - I'm not sure how to use the 10oz magnet model as it appears to have a bump on the bottom and even with 1uF highpass, wants to corner around 3K - how does one successfully use one with a high crossover?
mh-audio.nl/RLC_Series_Resonant_Calculator
If the mechanical Q causes a peak in the unfiltered response, aim for the RLC filter to make the overall impedance dip slightly around the driver resonance - this will give you a slight dip in the transfer function and flatten the freq response.
here's what I had for onhand for a RCL filter and 3.3uF 1/24th octave with the 10oz magnet Dynavox - that would add about $10 to the cost with an Erse 20ga coil - I'm out of alligator clips and forgot to graph it with a shunt inductor -
here's the 10oz magnet Dynavox vs Parts Express version with just capacitor highpass - the Parts Express
part really goes low - not sure how clean
- Dynavox paper cone (phenolic ring) tweeters
