Advice for line source please. - diyAudio
Old 25th July 2015, 10:56 AM   #1
Default Advice for line source please.
After examined Jim Griffins and John L. Murphys papers, we decided to build a pair of line source consisting of Aurasound NS3 and single Fountec JP3 ribbon tweeter. The tweeter will play / add-in from 10 kHz (+/-).
We have 50 e.a. Aurasound NS3-193-8A (8 ohm).
As I can see it we may have two options:
1) An array consisting of 24 e.a. NS3 wired as 2/2/4/4/6/6 (power tapering)
combined impedance should then be 4,36 ohm with system sensivity 96,5 db.
Pros: Power focused close to tweeter, optimized focus (less blooming)
Cons: Array system sensivity 1,5 higher than tweeter sensivity.
2) The other option is 25 e.a.NS3 wired for even impedance/power as 5/5/5/5/5.
This results in 8 ohm and a system sensivity 93,8 db
Pros: Real line source taking advantage of floor and ceiling ( array is approx. 2 meter high). Bigger sound due to blooming (delay due to different distance from ear to the different drivers)
Cons: Up-in-face sound, sound picture may be bigger than life (?).
(You feel like a fly in a trumpet)
I may for shure be wrong in this opinions/matters and ask for your experience and advice for this line source project. We also have the MiniDSP Dirac engine to play with, but want to make the basic speaker as correct as possible.
Short Line Array (line source) build perceval Full Range 226 4th January 2015 02:08 PM
new digital source advice kevinr Digital Source 11 24th September 2012 05:07 PM
advice for a new digital source resident Digital Source 3 14th August 2005 02:38 PM
Line Source Designs Oz_Audio Multi-Way 3 6th September 2002 05:33 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
