What does Fo (Hz) means??? - diyAudio
Old 16th July 2015, 12:18 AM   #1
Default Help tuning my enclosure
Alright, i bought two 1505-8BW, i did the enclosure at 2.7 cu.feet. with two ports each 3 inch wide. Now all i have left is to tune the enclosure with the length of the ports, but here is where i am completely unsure, which would be the best frequency for me to tune the boxes, ill use them as PA 2 ways system.
Most critical frequency response area? 192 Hz to 384 Hz hebrer Full Range 20 11th February 2015 09:00 AM
50 hz motor at 60 hz momin Everything Else 4 22nd August 2008 04:53 PM
need help wana change 60-Hz twin-T notch filter to 279 Hz filter prorms Solid State 0 9th February 2008 11:38 PM
Ultra Low Hz below 15 Hz Richard Moon Class D 6 6th October 2006 04:48 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
