#11 | |
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#12 |
diyAudio Chief Moderator
Hello,
This is what I use as a mic compensation file in WinMLS 2000. It shows much positive bass output deviation. Its a fact though, cause I have compared to a friend's well calibrated mic (professional loudspeaker designer) with the same program taking alternate measuements on the same setup. Also in RTA programs I get much bass on the graph if I dont compensate that much. Setting is C. Analogue RS spl meter RCA out. "Radio Shack low cost condenser mic (Salas)" "Hz" "Data" 20.0, 35.0 40.0, 12.0 55.0, 11.0 80.0, 8.0 100.0, 6.0 120.0, 5.0 200.0, -0.5 300.0, -0.3 400.0, -1.0 1000.0, 1.0 1100.0, -1.0 1300.0, -1.0 2000.0, 0.5 3000.0, 1.5 4000.0, 4.3 5000.0, 2.0 6000.0, 4.7 7000.0, 3.0 8000.0, 3.4 9000.0, -2.0 9500.0, -2.5 10000.0, -3.0 12000.0, -2.5 13000.0, -4.0 15000.0, -6.0 18000.0, -5.5 20000.0, -6.0 |
#13 |
I have found the SPL corrections published in several places, all the same. Your bass corrections are grossly exagerated I think, 35Db at 20 HZ?. I don't know where you got these, what is the origin?
Michael |
#14 |
Interesting, what is the model #? Mine is 33-2050 - purchased a long time ago (in 1990?)
I don't think the Behringer is out that much, so there must be substantial variation in the RS SPL meters... I haven't checked mine in the bass.
#15 |
Hello,
As I wrote I got em compared in a friends calibrated professional setup. The reason I did that it was that I kept getting too much bass in the graphs in all programs when I used all those readings I found on the web. I include I a pic I made just now. The top graph is my PC speaker left channel + sub (Cambridge Soundworks) without any compensation used. The bottom one is the same but compensated with the file I sent before. Radioshack analogue set to C. These thingies must variate wildly I guess. |
#16 |
Yes cat. no. 33-2050 'CHINA'
#17 |
Salas,
Is your radio shack SPL meter, the anaolg or digital, how old is it?
Michael |
#18 |
Its the analogue, roughly 3 years old, purchased in the USA
#19 |
I'm confused.
Your post says add 35 Db at 20HZ. But your "compensated" graph shows 15Db LESS at 20 HZ (goes from 5 to -10).
Michael |
#20 |
The upper one reads roughly - 8@20 when the bottom one dives under -30@20
| Zobel Network Corrections | fotios | Solid State | 11 | 22nd February 2007 05:03 AM |
| how to make this esr meter work with 250uA Panel meter | dytln_02 | Everything Else | 2 | 27th January 2007 10:13 PM |
| Rogers Cadet III schematics Corrections | jkeny | Tubes / Valves | 4 | 21st January 2007 08:23 PM |
| Making a milliAmp meter, become a Volt meter | redrabbit | Power Supplies | 11 | 26th May 2006 07:51 PM |
| Impedance Corrections for ESLs | G-Daddy | Planars & Exotics | 15 | 15th November 2001 01:16 PM |
| Page generated in 0.10747 seconds (74.13% PHP - 25.87% MySQL) with 11 queries |
