Active Accuton - diyAudio
Old 6th July 2015, 04:11 AM   #1
Default Active Accuton
Hello, I have been considering building speakers with Accuton drivers for a while. I really like their detailed sound. I recently had a chance to pick up the Clearwave Duet 6 as pictured below that sound fantastic, but of course lack the low end. These have Accuton C25-6, and C158-6 drivers.
I have an custom built IB subwoofer - If you don't know what they are - check out the build. Basically is it a sub that uses an infinitely large enclosure relative to the driver specs. In my case I use another whole room as the enclosure(+ 10 x Vas). There are 4x18" drivers with 4000 watts behind them. They have super crazy clean non-boomy bass and are flat to 10hz after EQ.
The speakers and the sub mate very well, IB subs easily mate with planar and stats, but I would like for the speakers to take on more bass duty from ~40-250Hz. The IB sub, I can keep for the low bass duty from 10Hz to 40Hz.
I am considering building a bass cab to handle 40-250Hz. The Clearwave speakers could sit on top of the bass cabinet - or probably be attached somehow for obvious reasons. This would be copying designs like Krell Modulari Duo Reference which just looks like a speaker on a bass box.
I would be doing this as an active digital crossover before the digital signal is converted to Analog. Most likely will use a MiniDSP unit to achieve a setup similar to Linkwitz LX521.4 newer OB speakers. So this means I would have an amplifier for each driver. Initially, I may keep the crossover in the Clearwaves and just have active crossover between them and the bass box. Later, I may bypass the crossover in the Clearwaves for pure active speakers.
I find I really prefer sealed boxes - I find they usually have tighter bass, and less boxy sound. But that could be my my experience with average consumer speakers. But being that I only need to go down to 40, sealed should be ok. I have owned Magnepan, Whispers, and Martin Logans and have become terribly allergic to boxy speaker sound...it seems that even speakers costing $20K+ have boxy sound.
Space and cost are not issues. Willing to build cabinets with very thick walls... The IB sub I built has basically an 11" thick baffle. Sometimes I have to control myself to not over build and over do things.
I would like comments and advice on at least the following
  • Am I nuts - is this dumb?
  • What is the ideal crossover point between the bass box and the C158-6?
  • What bass driver or drivers would you recommend? Looking for very high quality, quick, tight, accurate, fast, punch your gut, clean bass over 40-??? that would mate with the Accuton mid woofer. (I have heard that the Accuton woofers are not all that great compared to other offerings....true?)
  • How large of a driver/drivers should I use?
  • Thoughts as to the design of the box? I would insist on building something as inert and as braced as possible while also maybe having non parallel walls. I am not going to make these 11" think, but will have at least 2" thick walls and be well braced. I don't want them vibrating at all. I would not build anything curved at this point.
Thank you, Any and all comments welcome.
File Type: jpg 993126-clearwave-duet-6-loudspeakers.jpg (167.2 KB, 232 views)
Old 6th July 2015, 09:49 PM   #2
Inductor's Avatar
Making it with the Duets and a simulation of the enclosures as close to the original as I could you have (fig.1) for the 12-14L and 43Hz with bass response -3dB@42Hz. If you change it to a sealed (simulated, closing the ports with something flexible) speaker you get (fig.2) with a nice frequency drop at about F-6 dB/50 Hz to 150Hz/200Hz (flat), so that would be my target for the upper woofers or 40Hz - 150Hz. In 4*Pi (LF) you have 82.5 dB/2.83V/m (2*Pi 86.5 dB/2.83V/m) so that you know the sensitivity +/~required for the woofers since u will be multi-amp.
If you want to build a similar encloser to the pictured by you "Modulari Duo" you can use the similar alu ScanSpeak 8 or 10". In the same way you can use the very high quality Accuton woofers in a similar 90L sealed enclosure.
Considering that you have/need some BSC at some point with the room and speaker front baffle more the XO conjugate, you will have to match that with your subs (IB), that if you go with Accuton S220-6-221 8" link - you have in a 45L sealed plenty response to 40Hz (F-3dB@39 Hz) with one driver, having in 4*Pi 83.4 dB/2.83V/m and 89.5 dB/2.83V/m with two drivers in parallel and a sealed 90L.
Another driver (discontinued) you can consider using, in a ~90L sealed cabinet is the 25W/8565-01 - Scan-Speak (with F-3dB@37 Hz) and available at Meniscus.
Scan Speak, 25W/8565-01
In a 55/65L sealed cabinet with WOOFER 25W/8567-SE - Scan-Speak (F-3dB@39 Hz)
http://www.scan-speak.dk/datasheet/pdf/25w-8567-se.pdf
Have fun.
File Type: jpg ACCUTON C158-6-851, VB = 13.0 L sealed.jpg (93.3 KB, 176 views)
File Type: jpg ACCUTON S220-6-221, VB = 45.0 L sealed.jpg (91.9 KB, 177 views)
Old 6th July 2015, 10:02 PM   #3
I'd suggest 80Hz to 250Hz as being a lot more realistic.
rgds, sreten.
There is nothing more practical than a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 6th July 2015, 11:05 PM   #4
rgds, sreten.
Realistic? In what sense?
IB Sub: 4 X 18" @ 4000 Watts Build
Old 6th July 2015, 11:16 PM   #5
I have a friend that says I should be using a high quality 15" driver or 2 12" drivers to have some more viceral impact to the bass. I don't think I want to try the Accuton 11" at $1500 each. Any suggestions in that area?
Old 6th July 2015, 11:20 PM   #6
Have fun.
Thank you inductor I will check it out.
Old 7th July 2015, 11:18 AM   #7
Jonasz is offline Jonasz  Sweden
Jonasz's Avatar
I believe one Acoustic Elegance TD15S or two TD12S per channel would be ideal for your build.
AE Speakers Online Store
Old 7th July 2015, 02:59 PM   #8
Hi Bdlitzer,
I'm no real expert, but I've been thinking since long time to my future Accuton based speakers (hope this future is not too far), and I'm happy to give you some suggestions...
The C158-6-085 is probably the driver you are referring to, and not the C158-6-851, whose motor is much worse than the former.
So C158-6-085 will be probably my mid-bass, but if your budget is higher, you may consider two options: the C173-6-096E or the new CELL C90-6-724
The woofer for 80-250hz maybe an Audio Technology Flexunits 12 D 77 25 10 KAP with sandwich cone, or even the 15". Honestly I don't how they would compare to the new Accuton Cell woofers, 9 or 11 inches.
The crossover should be digital, ideally using FIR filters generated with software like Audiolense.These Xovers have important advantages when used with hard membrane drivers, since it's possible to send no signal at all at the breakup frequency. I think that most of the people who have found ceramic drivers harsh, must have dealt with their breakup behaviour.
Let's listen to other contribution and ideas
Old 7th July 2015, 03:11 PM   #9
Inductor's Avatar
I can model it again, just make a link to the right drivers. Cheers.
Old 8th July 2015, 09:28 PM   #10
You have low subs that that can easily go up to 80Hz.
There is no point IMO using them only below 40Hz,
and building stuff to go down to 40Hz if not needed.
rgds, sreten.
Accuton 3 way: Accu3 dsrviola Multi-Way 3 16th June 2013 04:31 AM
Active Crossover: Behringer x DBX active DriveRack 260 murillollirum Multi-Way 21 9th February 2013 07:12 AM
accuton...where ? ermes Multi-Way 0 10th December 2006 04:34 PM
Accuton drivers lwr Multi-Way 13 31st December 2004 01:17 AM
accuton drivers joz Multi-Way 6 10th May 2003 09:11 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
