Time to finish (veneer) my speakers
Old 5th February 2004, 07:03 AM   #1
Jean is offline Jean  United States
Jean's Avatar
Send a message via AIM to Jean
Default Time to finish (veneer) my speakers
Hello, I would like to hear some ideas and maybe even see examples of how I could finish my set of speakers.
Maybe someone could photoshop them for me ? I would like to see how they would look in dark red wood veneer all the way around, and also how they would look with a blank front instead of veneer (maybe leather?).
thank you.
larger picture of the top section - http://www.sacgti.com/speakers/tm-section.jpg
left lane is for passing, slower traffic keep right please.
Old 19th February 2004, 01:00 PM   #2
philip is offline philip  Canada
Default Finishing
Hey man, nice looking speakers. There are a few options that I know of. For my projects so far I have either used a primer then a specled paint (spray on) or a primer and a black matte coat. The matte coat looks really good when you use an orbital sander to round off the edges.
The other option, albeit harder and possibly suggesting the use of a cabinet maker, is to give them a piano gloss finish. I think you apply some sort of black bass, then sucessivly apply clear lacquer, buffing at each step. The other alternative is to apply veneer, then perform the same lacquer application steps. Example of these later 2 suggestions can be found at www.tidal-audio.de, under "cabinet finishes"
Good luck and God Bless,
Philip
Old 19th February 2004, 01:51 PM   #3
Synapse is offline Synapse  Canada
Synapse's Avatar
Those Cabinet are really nice! I was wondering how you assembled them? Screw/Glue?
I would personally see them with red Lauan or Mohagony veneer
wish I could see some construction pictures
truly awesome piece!
-Synapse
Old 19th February 2004, 02:40 PM   #4
Ropie is offline Ropie  United Kingdom
Ropie's Avatar
If they are MDF (looks like it) you could do what I did with my TLs - give them a coat of primer - I used ordinary emulsion coloured dark grey with cheap black acrylic paint (sanded smooth). Then use a small foam roller to apply several coats of black enamel gloss, the kind of paint used for kids' wooden toys. The cost of giving my S3TLs (just a bit smaller than yours) a 'piano lacquer black effect' was just under £5GBP and it looks fantastic.
The effect on your cabnets may be something like this...
Edit - sorry the pic is so small, for some reason the max file size I can attach is only 100k!
Old 19th February 2004, 02:52 PM   #5
Ropie's Avatar
Dark red wood veneer may look like this...
(and the free design consultancy ends here! )
Old 23rd February 2004, 08:45 AM   #6
Ropie's Avatar
Maybe you missed these
Old 24th February 2004, 06:36 AM   #7
Jean's Avatar
Thank you! I appreciate your response , still kinda deciding on what I want to do with them. I was thinking about possibly changing the shape a little bit to make it look a little better ...
They are made out of 1" mdf with butt joins and titebond glue. Top cabinets have 1 vertical brace , bottom cabinets have two braces forming a "T" shape inside the cabinet.
Time to finish (veneer) my speakersHide this!Advertise here!
Finish for DIY 3-way speakers trentki Multi-Way 3 1st November 2007 03:34 PM
Finishing speakers w/veneer? Emprov Multi-Way 4 21st June 2005 09:55 PM
Polyurethane ruined my speakers finish... kingdaddy Multi-Way 8 4th February 2004 12:35 PM
How to finish edges with veneer FrankDIY Multi-Way 18 10th February 2003 01:03 PM
Guide how to veneer speakers Stefan B Multi-Way 2 15th January 2003 01:52 PM
Copyright ©1999-2017 diyAudio
