The Martin King simulation for my ML-TQWT gave port dimensions Rport=1.0"and Lport=2.75", resulting in a (wanted) terminus resonance at 35 Hz.
I built the ML-TQWT with exactly these port dimensions. On measuring the woofer and terminus sound level response I found the resonance being at 30 Hz. In the simulation this would be equivalent to Lport~4". Is this a value I should have accounted for as end correction for the port? Or is it a inherent fuzziness of the simulation? What port length would you recommend to get the desired 35 Hz? Thanks for some helpful ideas. Rudolf
www.dipolplus.de |
#2 | |
Hi Rudolf,
I have had pretty good luck with the predictions from the MathCad worksheets correlating very closely with the near field measurements of the finished speaker. I am not sure why you got 30 Hz instead of 35 Hz but that is still not too bad. Have you rechecked the drivers T/S parameters to make sure what you input into the simulation is still valid? Did you measure and calculate the response without any stuffing? This is probably the best way to get a clean correlation between calculated and simulated responses. Hope that helps. |
#3 |
Thanks MJK
for making clear that the port dimensions in your worksheet are the actual dimensions. I havenīt been able to get the individual T/S-Parameters of my drivers since my measuring equipment isnīt properly calibrated (frequency measurements are valid of course). But I have seen T/S-Parameters for this driver from 3 independent sources, which fall into a 5% bracket for almost every single TSP. So I guess the driver is manufactured with high consistency but there is certainly still room for variation. Measurements (and simulation) were done WITH stuffing. So this might be another source of indeterminacy. A last factor that comes to mind: The port of my TQWT is not at the very bottom of the 42" pipe, but in the front baffle - port center 2 1/2" from the bottom of the pipe. Could this be accountable for some difference too? By the way: This discussion is really cherry picking since I am already highly pleased with the ML-TQWTs as they are. So my couriosity is more about the ins and outs of the simulation worksheet than any audible deficit. Thanks for your dedication and patience. Rudolf
www.dipolplus.de |
#4 | |
Hi Rudolf,
Glad you like the enclosure, |
#5 |
Hi MJK,
I have downloaded the Ported Box worksheet as you recommended. Just did a new simulation with my TQWT dimensions - especially accounting for the exact port position. Result: The woofer and terminus SPL diagram is almost exactly showing what I measured. Its some terrific work you have done! Two last questions - the first regarding the enclosure geometry definition of the worksheet: What is the meaning of the second expression in the SO/SL calculation - the subtracted value? I only entered the values for inner width and depth in the first part and ommitted the second part. Anything wrong with that? Second question: If I build enclosures with typical TML dimensions (aka "pipes") and simulate them with the Ported Box worksheet - would the stuffing still follow the rules of ML-TQWTs or should it be applied like in a normal BR box? Again, thank you for your much appreciated help. Rudolf
www.dipolplus.de |
#6 | |||
Hi Rudolf,
Sounds like you are making progress and having some fun, |
#7 |
==== This doesn't jive with my experience WRT how the vent location in a pipe affects the FR/Fb so I would appreciate it if you will post the driver specs and your cab dims. TIA, GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#8 | |
Hi Rudolf,
#9 | |
I tried out the download. Result look at picture below (I did a little composing ;-) though). I have no cue from what end of the line the discrepant outcome results. Rudolf
www.dipolplus.de |
#10 |
Hi Rudolf,
Missed that worksheet. It is fixed now. Thanks for pointing that out, |
| port length | jwhit67 | Multi-Way | 1 | 6th March 2008 12:29 PM |
| Help with port length please | Bobhof | Multi-Way | 3 | 2nd May 2006 06:32 PM |
| port length | busterno1 | Multi-Way | 5 | 27th October 2003 08:05 PM |
| port length | dave k | Multi-Way | 13 | 13th July 2003 02:32 PM |
| Page generated in 0.11986 seconds (81.50% PHP - 18.50% MySQL) with 11 queries |
