A month ago I bought a set of Labtec headphones. On the package it read: "Frequency Response: 20hz-20Khz". Now headphones aren't like speakers where you can kind of tell by looking at them, what they're going to sound like, so I bought them. I plugged them in and played a song, there was NO low end at all. I had to turn up the equalizer +20dB @ 60hz to get any kind of bass out of them and even then, they couldn't hit 40hz for anything. Also, the ground wire came loose in the headphone. How do manufacturers get away with lying so blatantly? I'm a bit wary when I see "20hz to 20Khz" on anything. It seems that's what consumers are looking for so mfg's just stamp that on the box. It strikes me as a little odd that different speakers with different characteristics all have the same frequency response. I'm more likely to buy something that says "23hz to 24Khz (-3dB)" because to me that means the product was actually tested. Now on a more positive note, I bought a set of titanium diaphragm headphones from RadioShack with a frequency response of "15hz to 25Khz" and I was thoroughly impressed. Car manufacturers aren't allowed to publish false horsepower figures so why are makers of "subwoofers" the size of lunchboxes allowed to claim they can hit 20hz? I just sent a complaint letter to Labtec, I'm waiting for a response.
#2 |
The answer is:
Labtec Sure, it "responds" at 20Hz but not at a level you can hear. Isn't that like drivers that have a LF rating below the Fs? |
#3 | |
I know Labtec isn't known for it's audio but that's why we have specs. The frequency response should be -3dB. NOBODY should be able to claim specs like that unless they're true.
#4 | ||
#5 |
Sennheiser defines what they mean by frequency response as follows:
"Frequency response (headphones) The frequency response of a pair of headphones is given within limits defined by the manufacturer." hehehe unfortunately they don't define what the limits are. BTW: they claim the FR of the HD650's are 10-39500 Hz. The HeadRoom site shows measurements for a variety of headphones. Though it may be more confusing--there are graphs using various sample rates and smoothing, etc. http://headroom.headphone.com/layout.php?topicID=10 HD600 (with heavy smoothing of the data) I've seen unsmoothed and lightly smoothed data (it looks like a roller coaster ride--same with all the other headphones, Sonys, etc.). AKG does refer to industry standards for headband pressure and SPL rating. http://www.akg.com/products/powersla...iew,specs.html But no standard for FR or THD. hehehe...if anyone has a clue what usefullness 0.05% THD means (with out a specified frequency--this is for Sennheiser and yes, it's probably 1khz), I'd like to know. Is this 0.05% at only one frequency? Headphones and speakers mfgs are a bit slippery with the specs... JF |
#6 | |||
#7 | |
#8 | |
Do you smell smoke?
The entire Bag End line of subwoofers is sealed boxes operating below the woofer's resonant frequency. Frequency response of the box/woofer is very predictable that way, and their crossovers are EQ'd to compensate... Peace |
#9 | |
Don't matter none to me. It still go zoom.
Davy Jones |
#10 |
Having the same displacement does not mean that they have the same cam or fuel and timing curves. You can buy a new computer chip to increase the power of your car.
Not necessarily a lie that the Corvette has more power. |
| Multifunction low distortion audio generator 20Hz-20kHz | Indesigns | Vendor's Bazaar | 0 | 17th April 2009 09:59 PM |
| I got your 20Hz-20Khz Right here !!!! | sumsound | Multi-Way | 21 | 19th August 2008 07:45 PM |
| Page generated in 0.12717 seconds (79.80% PHP - 20.20% MySQL) with 11 queries |
