My first DIY speaker. Using a kit. Needs suggestions - diyAudio
Old 21st May 2015, 11:29 AM   #1
Default My first DIY speaker. Using a kit. Needs suggestions
Hi.
I want to build a speaker. I have no experience in designing crossovers so I figure I will go with a kit. My amp is an Yamaha AS1000 and i play mostly vinyl.
I like tight bass and defined midrange. Which kit would you go for.
Im thinking of either:
SEAS CURV
18W-8434G00
IDUNN
Please share your experience
Old 21st May 2015, 02:34 PM   #2
Send a message via AIM to SpeakerScott Send a message via MSN to SpeakerScott Send a message via Yahoo to SpeakerScott
Originally Posted by antonomnell View Post
Hi.
SEAS CURV
18W-8434G00
IDUNN
I am a huge fan of controlling directivity in loudspeakers. It's not *necessary* for high quality reproduction, I've listened to and designed a lot of loudspeakers with purposely wide dispersion patterns. However, the idea that you can help eliminate some variables in your system reproduction performance, namely frequency and time distortion of delayed reflections is a huge benefit.
For that reason...I would suggest the IDUNN is your best bet of the ones you've listed. I might put in a plug for my own design (listed below). I've got an update coming soon that uses a controlled directivity tweeter (Vifa, not the Seas unit) instead of the wide dispersion Dayton unit.
The DIYRM won't go as loud as the IDUNN, but it's significantly smaller if space is a concern. It may also be an easier cabinet construction.
Scott
Old 26th May 2015, 08:16 PM   #3
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Here's a good one. Could be a "reference" type loudspeaker. No box to build. Just need to cut some pipe. Can get the wood pieces from Madisound.
It does need 4 amp channels or 2 stereo amps.
LXmini Challenge
I build, therefore I am.
DIY speaker suggestions hameay Multi-Way 26 10th August 2013 11:26 AM
Suggestions for smallish desktop speaker kit, no sub matt_garman Multi-Way 1 1st December 2012 10:21 PM
DIY Speaker Suggestions to use with F5 1108 Pass Labs 9 19th June 2011 09:08 PM
suggestions - my first DIY speaker stephen123 Multi-Way 2 18th January 2009 06:43 PM
DIY speaker upgrade suggestions Sparhawk Multi-Way 3 16th February 2006 11:15 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
