Old 3rd February 2004, 03:21 AM   #1
Default Does the DCR of parallel inductors matter?
Some suggest using lower quality/priced components in the non-signal critical areas of crossovers such as paralleled components that are effectively only shunting to ground.
But does the DCR of coils matter here as much as it does in the signal path?
Mos
Old 3rd February 2004, 03:47 AM   #2
diyAudio Moderator Emeritus
roddyama's Avatar
So the question is whether the distortion created by a parallel component that shunts to ground can affect the signal to the output, in this case a speaker.
If you assume the distortion is in fact generated in a “lower quality” component, that distortion will be manifest in a voltage other than ideal (different from the signal). Since the component is shunting from the signal path to ground, it has at least one node (connection) in the signal path. The distortion generated by the component has to exist at this signal path node. So the answer has to be yes, this component, even though it is not in the signal path, will affect the actual signal.
So the real question should be will the “high quality” component generate less distortion than the lesser quality component, in the signal path or not?
Rodd Yamashita
Old 3rd February 2004, 04:11 AM   #3
What I'm asking is not related to distortion, it's related to the resistive action of a parallel component. Unless you count resistance as distortion, that is.
So, explicitly: does a higher resistance coil in parallel with the signal path impart any more resistance to the signal path than a lower resistance coil would?
Mos
Old 3rd February 2004, 04:26 AM   #4
roddyama's Avatar
Mos
The resistance of the signal path is what it is regardless of any parallel resistances. The overall signal path, including parallel resistances has less total resistance when the parallel coil has a lower DCR.
Rodd Yamashita
Old 3rd February 2004, 10:43 AM   #5
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Hi Mos
I read somewhere that the DCR of the inductor should be less than 10% of the voice coil DCR.
So for a driver with a DCR of 5.7ohm the inductor should have a DCR less than 0.57ohm.
Apparently so it has little affect on the driver Q. Thiele states that 5% will not affect driver Q.
Hope this helps.
Inductors in series/parallel? QED047 Class D 6 11th August 2009 03:10 PM
Parallel inductors (dumb question) w/ Zobel followup arc2v Multi-Way 11 19th November 2007 08:59 PM
Parallel Inductors in PSU monarodan Pass Labs 22 2nd January 2007 02:19 AM
Parallel amps & Parallel Voice coils? officeboy Multi-Way 7 26th May 2004 07:12 PM
pi filter in class a amp: okay to parallel inductors? jwb Solid State 6 20th October 2002 07:56 PM
Page generated in 0.08961 seconds (73.35% PHP - 26.65% MySQL) with 10 queries
