3-Way Floor Standing Driver Selection
Old 8th May 2015, 05:15 PM   #1
RamblinMan is offline RamblinMan
Thumbs up 3-Way Floor Standing Driver Selection
OK,
I have selected the following drivers based on my limited knowledge of speaker design. I would like some feedback now because I plan to purchase a die for an aluminum extruded cabinet based around the drivers I have listed below.
Quantities are per speaker
QTY 2) HiVi M8N 8" Aluminum/Magnesium Woofer
QTY 1) Goldwood GM-85/8 Heavy Duty 5-1/4" Sealed Back Midrange 8 Ohm
QTY 1) Dayton Audio DC28F-8 1-1/8" Silk Dome Tweeter
The goal is to have some good looking speakers that sound good too. At least as good as a pair of speakers that would cost around 2K.
Old 8th May 2015, 06:19 PM   #2
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
$2K wouldn't cover the cost of making the die. Don't understand why you would go this route, unless you plan for a production run destined for retail.
jeff
Old 8th May 2015, 06:41 PM   #3
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
jeff
Goldwood sealed ack midrange ?
Dayton tweeter ?
2 X Hi-Vi woofers ?
you must be crazy ! To reach the 2k value you have to invest money in: some fancy morel woofers, some scan speak/seas exotic midrange and...wait, I heard from the community that SB are quite good!
Then some boutique caps, some flat copper bobbins and real graphite resistors to make the x-over. Don't forget OSFC-LL 99.9999999% pure copper for the wiring...the binding posts would then be extruded from pure-solid copper either
Old 8th May 2015, 07:51 PM   #4
jeff
I work regularly with a extrusion company designing extrusions so the die will not be expensive. Retail? More or less the ability to reproduce the speakers for friends and family easily if they turn out well. After the cost of the die, I'll be paying less than $2.00/lb.
Old 8th May 2015, 09:27 PM   #5
Dayton tweeter ?
2 X Hi-Vi woofers ?
I am crazy! Seriously though, I appreciate the honesty. A quick look into some of the brands you mentioned and it looks like it will cost me 2K which is not what I would like. Maybe my price example isn't the right way to put it. I want quality sound with a relatively flat response from ~50hz-24khz. Is this more crazy talk?
Old 9th May 2015, 05:38 AM   #6
No, it's not a crazy talk and you are on the right way. Ideally you'd want a stiff cabinet for the " power element" - the woofer. So this enclosure would need to be stiff in order of not letting the soundwaves passing thru the walls ; the woofer needs a hole in order to be mounted and at least eight holes in the surround to be fixed. Once you have done that, what's the result ? The woofer membrane is the fragile part ! So it depends on how the pressure from the bacwave is "treated". I would focus on the woofer enclosure only. You can place mid& tw outside; well, hey! "So I would need to put the woofer on the very side of the enclosure in order to reduce the interdistance at minimum ?!" No if you make the wall slanted ...
OR...you can proceed with your idea of putting two woofers and make a cabinet for them. You can then experiment if they sound better vertically or horizontally
The midrange unit would need to be the most better part ! Absolutely not a closed back stell capsule ; many in this forum report the Seas 10 F (...) to be a good performer...it's 4Ω (?); also the tweeter...well, the tweeter...
But FIRST you have to connect electrically all these units and make them well behaving, and if you are not skilled in crossover design is a lost game, as the X-over is "the heart" of a loudspeaker system
I might suggest you a very-minimal series crossover design, and to make that you need : a very efficient midrange ( so, no Seas ) and a tweeter with ferrofluid in the gap.
Old 9th May 2015, 07:46 AM   #7
andy19191 is offline andy19191  Europe
The configuration is a good one but in order to match a good 2k speaker you will need to spend more on drivers and a significant amount on crossovers. If you look here you can see the price of a few examples with your driver arrangement. This suggests around $500-700 would need to be spent on parts.
I assume you do not know how to design a 3 way crossover or choose which drivers will fit and which will not. This is going to take a fair chunk of tiime to learn if you want to design your own speakers but can be fun if you are that way inclined. Of course one or two things will almost certainly be not quite right in the first effort even if you don't immediately spot them and so you should perhaps plan for this.
A viable alternative that avoids a lot of up front learning might be to largely follow an existing published DIY design in terms of driver layout, baffle size, enclosure volume and crossover. Of course not all DIY designs are of equal competence so it might be wise to check if you settle one.
Old 9th May 2015, 09:03 AM   #8
fatmarley is offline fatmarley  England
If I had a pound for every time I left a link to THIS!
Have a good read of that before you do anything.
It took me forever to get a 2-way sounding good and knowing that a 3-way is supposed to be much, much more difficult - I'm glad I started with a simple 2-way.
It may be worth investigating active crossovers rather than passive. People seem to get good results much quicker than when going passive.
Old 10th May 2015, 03:50 AM   #9
system7 is offline system7  United Kingdom
system7's Avatar
Terrible choice of drivers that the best cabinet in the World can't redeem.
Here's how to do a decent three way:
SEAS-3-Way-Classic
He's using a straightforward Steen Duelund approach. Maybe you could improve it, and a SEAS metal tweeter might work better, but not bad at all.
Best Regards from Steve in Portsmouth, UK.
Old 11th May 2015, 09:30 PM   #10
I want to thank everyone for all the great info. I will continue reading on drivers and crossover design while I work out the extrusion. Resonant frequencies in aluminum suck.
3-Way Floor Standing Driver SelectionHide this!Advertise here!
4 Way floor standing speakers and crossovers elrosh Multi-Way 13 17th December 2012 06:39 PM
EL70 Floor-standing Choices KyleinCowichan Full Range 68 19th November 2012 03:58 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 06:42 AM
Glasses - a floor standing speakers. cryptic Multi-Way 0 13th July 2011 08:15 PM
Floor standing speaker stand msjd4 Construction Tips 0 3rd January 2010 03:02 AM
Copyright ©1999-2017 diyAudio
