Old 2nd February 2004, 09:43 AM   #1
sma is offline sma  Indonesia
Default Diy Audax
i have 1 pair of audax HM170G8 and 1 pair of audax TW034XO tweeter.i interest for building 2 way loudspeaker,anyone have suggest about box size and crossover schematic for this configuration?
Old 2nd February 2004, 10:27 AM   #2
Taco is offline Taco  Netherlands
I only know the HM170G8, and this woofer works perfectly in an 18 - 22 liter cabinet. With a F3 of about 50 hz. A simple first or second order x-over suffices.
Old 2nd February 2004, 10:34 AM   #3
Ouroboros's Avatar
The TWO34 has its fundamental resonance below 900Hz, so it works well with a first-order crossover if you are setting the nominal crossover frequency to 3000Hz or so.
It WILL need a series L_C_R network across it to compensate for the rise in impedance at resonance. (Otherwise you'll find that your high-pass filter isn't behaving as you expected it to).
I use this tweeter myself with such a crossover with no problems.
(If no-one responds with the resonance compensating network values, I'll check this evening with what I used and post it tomorrow).
Chris Morriss.
Old 3rd February 2004, 07:14 AM   #4
Ouroboros's Avatar
As a resonance compensating network, I use a series L-C-R network of 1.2mH, 33uF, 10R across the tweeter.
Old 3rd February 2004, 07:58 PM   #5
thank you ouroboros.i will try your schematic..
any one have suggest for woofer box?
Old 4th February 2004, 07:17 AM   #6
Ouroboros's Avatar
To make a first order crossover work adequately, it would also be wise to place a network across the bass unit to compensate for the rise in impedance as the frequency increases. For the HM170G8, a series R-C network of 8.2R + 12uF is about right.
The resonance compensating network across the tweeter, and the inductance compensating network across the bass unit means that the drive units now present a much more constant impedance load to the crossover.
With these networks in place, you can then calculate the value of the series 'L' for the bass unit filter, and 'C' for the tweeter filter, assuming a constant 8R load. (It won't be perfect, but it will a LOT better than if the speaker impedance had not been compensated for.)
Old 4th February 2004, 08:06 AM   #7
I used 10ohm + 10 uF zobel on the woofer. And a 18 liter enclouser tuned to 50hz.
Old 4th February 2004, 08:25 AM   #8
Ouroboros's Avatar
Actually you really need to measure the resonant frequency of the bass unit in its cabinet to determine the resonance compensation network. I've only ever done this for sealed box systems.
(Reflex loudspeakers are the work of the devil! (IMO of course)
Old 4th February 2004, 08:42 AM   #9
Ouroboros's Avatar
Oh Oh, I really should THINK before posting!
There's only an inductance compensating (Zobel) network on the bass unit. No resonance compensator!
!0r + 10u or 8R +12u aren't too much different in real life.
(I now go away and hang my head in shame)
Old 4th February 2004, 10:06 AM   #10
hi everybody,
how about inductor value for this HM170G8?assume use 18 litre box in 50hz.
So the zobel network is 10 mf + 10 ohm.I will try it.
Audax DIM Multi-Way 11 9th March 2006 08:34 PM
2-way audax bhg41088 Multi-Way 1 23rd July 2004 04:38 AM
Audax Sd value Svante Multi-Way 6 28th April 2004 10:46 PM
son audax sma Multi-Way 0 27th December 2003 11:40 AM
Audax HT xr628 Multi-Way 1 16th January 2002 07:42 PM
Page generated in 0.08524 seconds (86.83% PHP - 13.17% MySQL) with 11 queries
