Which is which ?
Which is which ?
Old 1st February 2004, 06:52 PM   #1
fireman is offline fireman  Canada
fireman's Avatar
Question Which is which ?
I got my TB W3-871S in the mail last week. I am about to put the final touches on my first two "rough" enclosures. But before I go ahead and put the drivers in, I've gotta ask a stupid question.
There is a wide and a narrow connector on the speakers. Which one is the positive and which one is the negative ? I guess there must be a convention for this kind of stuff but I don't know it. Can somebody help me ?
Let's hope I'm finished before the Superbowl. I'll be able to break them in as I watch the game.
Old 1st February 2004, 06:58 PM   #2
GM is offline GM  United States
GM's Avatar
Standard convention is the wide one is the positive, but to be sure, if you have a 1.5V battery and some insulated wire available you can easily check it.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 1st February 2004, 08:20 PM   #3
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
Which is which ?
Take a close look at the terminals. You will see that TB has kindly moulded in a "+" and "-" into the terminal strip.
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 2nd November 2004, 04:11 PM   #4
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
That's true, you can check with a 1.5V cell. However, DC from the cell is below resonance and we operate moving coil loudspeakers above resonance, and there's a 180 degree change of phase between the two. This means that if the positive terminal of the cell moves the cone towards you, this is actually the negative terminal.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 2nd November 2004, 05:26 PM   #5
Timn8ter is offline Timn8ter  United States
Timn8ter's Avatar
Standard convention applies with the W3-871S.
Which is which ?Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
