Crossover Help - diyAudio
Old 15th April 2015, 08:25 AM   #1
juancho is offline juancho  United Kingdom
Default Crossover Help
The attached shows the crossover in my Wilmslow Audio Prestige speakers. They are 70 litre cabinets running Monacor 12ins bass units, ATC mid ranges, and Vifa tweeters. The ATC SM75-150 has recommended crossover points of 380 and 3.8khz.
I would like to know what the crossover is giving in terms of crossover points.
Also, I know my listening room has a big bass drop out, but these speakers give subjectively less bass than my previous Elac FS207s with 2 x 6.5ins drivers which does not seem right.
Thanks for any help.
David
Sent from my iPad using Tapatalk
Old 15th April 2015, 09:40 AM   #2
AllenB is offline AllenB  Australia
This looks like a fairly text book crossover that's been adjusted, presumably to fit the drivers and enclosure. Assuming polarity is correct etc, a bass issue is more likely fixable in where you put the speakers and where you sit.. or in where you place subs.
Old 15th April 2015, 10:26 AM   #3
Happy to attempt to model it for you but need to know the actual bass driver and tweeter, and cabinet dimensions
Old 15th April 2015, 03:51 PM   #4
Hi Nannoo,
That would be brilliant! The bass unit is Monacor SPH300CT, and the Tweeter is
Vifa D27TG-35-06. Cabs are 70 litres and cabinet dimensions 1050mm high x 360mm wide x 330mm deep. The cabinet is not rectangular and I will attach a photo to a second post.
Thanks for the help!
David
Old 15th April 2015, 03:54 PM   #5
Here's what the speakers look likeClick the image to open in full size.
Sent from my iPad using Tapatalk.
Old 20th April 2015, 01:14 PM   #6
Did you use a different reflex pipe for this compared with the one used for the Volt bass driver? It seems unlikely that they would use exactly the same tuning.
Old 20th April 2015, 01:21 PM   #7
Wilmslow supply exactly the same tube
Old 20th April 2015, 01:34 PM   #8
I bet they do. The speaker is designed to use the Volt driver in all three variants I believe. The chances of the Thiele and Small parameters being the same for your bass driver and the intended Volt driver are very small I would guess. T&S parameters are solely concerned with bass performance so this could be part of your bass performance problem.
Old 20th April 2015, 01:47 PM   #9
Just for instance, a quick look at the Wilmslow Audio website shows the free air resonance of your Monacor drivers being 18Hz while the Volt used in the design is 35Hz, this is very close to a whole octave in difference.
Old 20th April 2015, 05:52 PM   #10
The speakers manage to sound great in my friend's house despite all the compromises in their 'design'.
Most of my bass problem is room related and the purpose of this thread is for me to gain understanding of the crossover design before tweaking and / or upgrading things
Help needed to decide: DIY Active Crossover or Passive Crossover? raelman Parts 5 1st October 2014 03:19 PM
BSS active 2-way/3-way crossover, ADS PX Concept 2-way crossover Busyx2 Swap Meet 0 3rd June 2014 07:52 PM
Can you use a digital active crossover to design a passive analog crossover ? RickDangerous Digital Line Level 27 1st April 2013 05:59 AM
Crossover Inductor DCR Values and General Crossover Advice Wayniac Multi-Way 6 15th December 2012 02:59 AM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
