I'm thinking about building a custom open back cab for my guitar head as my first non-car audio project. It seems like PartsExpress should be able to provide me with everything I need from corners to laminate. However, I am still confused on what speakers to purchase. I want the cab to consist of two 12" speakers. I know Marshall, Mesa, Crate and many others choose Celestion G12's for their cabinets. Do the Celestions really sound any better than say a Pyle?
I noted that the specifications of the Celestion G12 is very similar to many other speakers sold by parts express. I want to build a cab that sounds good but don't really want to pay for name brand speakers if something cheaper will sound just as good. Anyone have any suggestions or experience. Additionally, is there any noticeable difference in the sound quality of two 4 ohm speakers wired in series...versus...two 16 ohm speakers wired in parallel assuming the the rest of the specs for the speakers are consistent? Thanks. |
#2 | |
Although your question is interesting I really can't help you, however I am particulary interested in this question...never really thought about it till now
#3 | |
2) What's your budget and equipment like? Do you have a Les Paul Custom into a Marshall head? Then use Celestions. Do you have a Squier Strat into a transistor amp? Then use Eminence. 2) Jimi Hendrix turned over in his grave when you used Celestion and Pyle in the same sentence.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#4 |
Guitar speakers cannot be judged by their parameters at all.
I'll just note that for an open backed cabinet the drivers with Fs of around 100Hz and a Q of around 1.1 are the ones to go for, the lower Fs and Q's suiting sealed cabinets. Guitar speakers are about tone and progressive distortion. Eminence are very good value, generally with guitar speakers you get what you pay for, but making the correct choice of the type of guitar speaker tonally to suit you is paramount. |
#5 |
Here are a few links with sound samples from different guitar speakers:
http://professional.celestion.com/gu...one/index.html http://www.proguitar.de/AudioDemo/Co...reSpeaker.html It's quite easy to hear the difference |
#6 |
I've got a pair of Celestion Greenback G12S 16 0hm each,20w rms each out of a broken valve Selmer guitar combo amp my Uncle gave me.
Tried them in the original cabinet [2x 12 inch vented] and I don't know what makes the speaker sound this way but it has an unique sound to it when used with my mates Marshall valve head. Just wonder if there is any difference between the greenback G12S [which ive got] and the G12M they have nowadays??? |
#7 |
Thanks to all that replied. I have decided to go with 2 Eminence Legend M12 (16 ohm) speakers as this cab will be used for rock/metal.
Can anyone provide some advice on the type of wood? I orginally planned on using 1/2" MDF but after talking to the owner of a local guitar store he told me that a lot of cab manufactuers are going with Plywood instead of MDF. I would think that MDF would have less overall resonance and accent the lower frequencies more than Plywood...any suggestions? Thanks. |
#8 |
diyAudio Editor
Plywood is a LOT lighter and won't be destroyed in a month!
#9 | |
#10 | |
| 4x12 Guitar cab using guitar and bass speakers help | andrewskaterrr | Instruments and Amps | 15 | 23rd April 2009 11:43 PM |
| Built differences between Guitar Speakers and PA Speakers? | agadis | PA Systems | 7 | 24th September 2007 08:22 AM |
| Blew my speakers with a guitar - can I fix them. | mga | Multi-Way | 26 | 6th August 2006 09:29 AM |
| Bass guitar amp/speakers | Jorge | Instruments and Amps | 19 | 4th October 2005 10:48 AM |
| guitar speakers | 9am53 | Multi-Way | 0 | 3rd May 2005 08:51 PM |
| Page generated in 0.11796 seconds (79.56% PHP - 20.44% MySQL) with 10 queries |
