Manninen presents: Steel is Real
Old 7th January 2018, 03:36 PM   #241
manninen is offline manninen  Finland
manninen's Avatar
slightly smaller horn mount 40% done.
for phase plug im gonna use POM, alu could be better. inside voicecoil less inductance?
Old 8th January 2018, 06:11 PM   #242
manninen's Avatar
done, have to buy some black modeling clay to fill it up, jig saws angle is so loose result +/- 5degrees, at least drill were quite good.
Old 9th January 2018, 06:45 PM   #243
manninen's Avatar
phase plug partially done, ive measured 107mm from cone outer and inner to horn mouth, from cone 87mm, 20mm difference
Can it go to 4000hz with good phase response?
Old 11th January 2018, 05:32 PM   #244
manninen's Avatar
clayd and fitted to horn, think gonna take some quick measurements
Old 11th January 2018, 05:50 PM   #245
manninen's Avatar
first blood with random phase plug
reasonable phase curve
Old 12th January 2018, 05:35 PM   #246
manninen's Avatar
bit scaried starting to measure
Old 14th January 2018, 07:50 AM   #247
manninen's Avatar
plug is 60mm, random plug is 85mm and different shape.
Thinking what to do next
this is the random plug in same window size
Old 14th January 2018, 10:59 AM   #248
manninen's Avatar
That martin ring does its jobs 400-2100hz
this needs only one 3db notch
Old 1st February 2018, 11:50 AM   #249
manninen's Avatar
mouth is too large, maybe over 70cm2, i wanted it to be 50cm2
and path from cone to mouth is uneven
today i evolve my sharp plywood throat more into raw modeling clay way.
sand section B couple mms larger.
im gonna stick 400hz-2.2k range as tpl200h is ok with 2.2k
im bothered with 25y old jigsaw so gonna buy a new one
Old 4th February 2018, 09:53 AM   #250
manninen's Avatar
Slight mismatch second throat, have to sand it down little bit.
wanted to try something new so build a new sub, found rather good spot from the room so building another one
Manninen presents: Steel is RealHide this!Advertise here!
Rundmaus proudly presents... Rundmaus The Lounge 5 12th August 2014 09:53 PM
Presents the National Anthem of Your Country FullRangeMan The Lounge 2 16th August 2012 10:44 PM
Merry Christmas! What did you get for presents? Ninesvnsicks The Lounge 8 29th December 2011 06:41 PM
Brian Wilson presents SMiLE!!! Apogee Music 18 24th November 2004 06:31 PM
