Manninen presents: Steel is Real
Old 6th September 2017, 12:57 PM   #231
manninen is offline manninen  Finland
manninen's Avatar
about the manifold, or mannifold may i say
8cm thick easily fileable mdf
drill holes to angle where path lenght match
this radial type interests me too
Old 13th September 2017, 10:46 AM   #232
manninen's Avatar
went to dual channel fft
whoaa!! now i think car dsp is easy to tune, just keep other pcs ARTA sniff live pink noise phase and tune dsp with other laptop
Old 16th October 2017, 07:30 PM   #233
manninen's Avatar
tuned in with Harsch xo using smaart, now thats a good software.
got those wood carving tools so have to start doing that midhorn manifold #231
Old 22nd November 2017, 06:34 PM   #234
manninen's Avatar
Now thing started to move on. modeling clay to get easy 100% custom shape.
some measurements for reference before clay, i hope i can keep my microphone setup untouched so measurements are comparable.
Old 22nd November 2017, 07:19 PM   #235
manninen's Avatar
and here is hornresp sim of jbl cinema horn. upper is with extended and lower is stock.
Old 23rd November 2017, 03:44 PM   #236
manninen's Avatar
dauumm!!
Old 23rd November 2017, 04:33 PM   #237
manninen's Avatar
really start to look similar to funktion one
but can i make it better?
Old 25th November 2017, 01:08 PM   #238
manninen's Avatar
mouth is too large, maybe over 70cm2, i wanted it to be 50cm2
and path from cone to mouth is uneven
Old 6th January 2018, 03:28 PM   #239
manninen's Avatar
just wasted couple of hours of my life again.
path from voicecoil and outer went uneven.
well i have to check it out again from scratch
Old 6th January 2018, 05:32 PM   #240
manninen's Avatar
okay, if someone follows i have question.
this has 43mm from cone outer to spot marked as 1.
44mm from voicecoil and 20mm from cone.
to spot 2 measurements are 35mm, 28mm and 0.
what are cancellion points? or how high it should response.
Manninen presents: Steel is RealHide this!Advertise here!
Rundmaus proudly presents... Rundmaus The Lounge 5 12th August 2014 09:53 PM
Presents the National Anthem of Your Country FullRangeMan The Lounge 2 16th August 2012 10:44 PM
Merry Christmas! What did you get for presents? Ninesvnsicks The Lounge 8 29th December 2011 06:41 PM
Brian Wilson presents SMiLE!!! Apogee Music 18 24th November 2004 06:31 PM
