Manninen presents: Steel is Real
Old 2nd April 2015, 02:50 PM   #11
manninen is offline manninen  Finland
manninen's Avatar
more stuff bought today, i hope i have time to do something today
cutting, welding and grinding
Old 2nd April 2015, 04:23 PM   #12
peterbrorsson is offline peterbrorsson  Sweden
Originally Posted by dragonweed View Post
Come on guys.... That is the skeleton of the Magico Q5, a sixty-grand (US) 180kg, 4-way sealed box without the "skin".
I was asking Manninen if an ob is in the process ;o)
Old 3rd April 2015, 01:13 PM   #13
manninen's Avatar
welded and brazed
Old 5th April 2015, 12:25 PM   #14
na is offline na  Finland
Got a truck lift?
Old 5th April 2015, 12:34 PM   #15
manninen's Avatar
40,3kg baseplate with standing pipe. i donīt know if welding joint is liquidproof, meaning if just filling pipe with sand is not enough, there goes sand/oil.
No reason to do much before got the speakers from france
Old 10th April 2015, 08:43 PM   #16
manninen's Avatar
strongline, 940grams each
found this gary hīs steel project
http://www.diyaudio.com/forums/multi...en-baffle.html
i hope mine is finished before his.
about 11/36 days gone from the order
Old 24th April 2015, 09:10 AM   #17
manninen's Avatar
Didnīt win edbkīs nc1200 auction so need some amplification
Couple of cat5 and few dawg5
Old 17th May 2015, 05:16 PM   #18
manninen's Avatar
Ok, letīs stop this mystery
speakers weīre/are
beyma tpl-200h
phl audio 3450
phl audio 7201nd, this is we`re because phl cant make basket anymore some how atleast this point.
i ordered these 3/26/15, and yesterday got mail about 7201nd incident and i swap bass into bms 18n862, bit more hardcore specs. 4-6weeks to get these so i will be making snowmans before getting these fully done
I had in mind that i install speakers magnet mount but that too i swap bit more into
tentacle mount.
i hope i receive midīs and highīs within 10-14days so iīll start making those mounts next week
https://www.youtube.com/watch?v=9ePIZugahFc
letīs hit it with cruel summer cause waiting these is too cruel
Old 20th May 2015, 05:05 PM   #19
manninen's Avatar
Old 20th May 2015, 10:12 PM   #20
LineSource is offline LineSource  United States
LineSource's Avatar
Posted a sealed box simulation of the PHL 3450 using T/S parameters from their website: F3 ~ 224Hz in a 0.13cuft sealed box for Qtc=0.71. Most designers favor the superior transient response and low phase shift of a sealed midrange. The PHL 3450 spec has an Fs of 80Hz and Qtc of 2.4, so a ported box ~ 0.4 cuft tuned to 130Hz can provide -3db of 125Hz with a modest bass shelf.
The 18" BMS 18N862 woofer datasheet SPL looks up to the challenge of even a 225Hz crossover needed for the sealed box PHL 3450. BMS 18N862, VB = 179.1 L, FB = 22.9 Hz, F3=33 Hz,
The Beyma SPL plot for the TPL-200H suggests a 2KHz crossover, an LR4 slope would be a good first simulation. The TPL-200H is Beyma's highest efficiency and highest power handling AMT. The Beyma TPL-150H treads emphasis the need to select a midbass crossover frequency which has a polar pattern similar to the 80H x 30V of the TPL-200H horn. I could not find a polar plot for the PHL 3450.
Manninen presents: Steel is RealHide this!Advertise here!
Rundmaus proudly presents... Rundmaus The Lounge 5 12th August 2014 09:53 PM
Presents the National Anthem of Your Country FullRangeMan The Lounge 2 16th August 2012 10:44 PM
Merry Christmas! What did you get for presents? Ninesvnsicks The Lounge 8 29th December 2011 06:41 PM
Brian Wilson presents SMiLE!!! Apogee Music 18 24th November 2004 06:31 PM
Copyright ©1999-2017 diyAudio
