Manninen presents: Steel is Real - Page 3 - diyAudio
Old 21st May 2015, 02:31 PM   #21
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
LS, I happen to know that this one will not have boxes...
AINOgradient speaker project
Old 22nd May 2015, 05:08 PM   #22
manninen's Avatar
Old 22nd May 2015, 07:03 PM   #23
manninen's Avatar
https://www.mixcloud.com/m50/m50-vie...uhle-20150516/
good mix. leaned one hour to 30v/35volt output limiters
Good to have infinite volume knob
Old 23rd May 2015, 02:12 AM   #24
LineSource's Avatar
Heavy Metal dipole speakers like the Kylon Gaia, with the help of extensive DSP and watts-watts-watts, have been getting good reviews. Kylon mounts all speakers by their motor to a massive metal skeleton to minimize baffle vibration. Kylon woofers have dipole optimized T/S parameters(Lambda TD12D, TD15D).
I believe that there is Order even in a Chaotic Universe. The selected drivers are very well suited for a high efficiency 3-way sealed box speaker. The entropy of the audio universe will gradually move them in that direction.
--high efficiency 3-way sealed box speaker.
beyma tpl-200h
phl audio 3450
bms 18n862
In California we still remember the Beach Boys.
"Round...Round...Get a'Round....I get a'Round"
Music of the Sphere
Old 23rd May 2015, 05:26 PM   #25
manninen's Avatar
Old 26th May 2015, 05:35 PM   #26
manninen's Avatar
these are ready, and pulled all leftover wires to amps. 8-channels are ready but after 2 months no speakers. Sent message about cancelling order, day 2 and no answer
this is 2015
Old 27th May 2015, 07:16 PM   #27
manninen's Avatar
Things have changed in court of appeal.
now i have
high: tpl200h
mid: ?
lower mid: ?
low: 18n862
thinking phl 1130 to mid 500-2000 but could need heavier low mid, maybe 12" or even 15" to get that hit. 80/200-500 is bandwith maybe.
exploid my hifi 6/2 and got first impression 420-2500hz nude.
are you ready?
Old 27th May 2015, 09:11 PM   #28
Legis is offline Legis  Finland
Legis's Avatar
Things are about to get serious .
Old 28th May 2015, 03:24 AM   #29
LineSource's Avatar
Sealed Boxes. A smooth controlled directivity curve across the TPL-200H "desirable" 2KHz crossover needs a midbass speaker which has ~80 degee(+/- 40) directivity @2Khz. The attached polar measurements of the old 10" JBL 2123H shows that this is possible with a few 10" speakers. Curvelinear cone? Triple roll surround?
The year 2015 $170 Beyma 10MI100 version2 has the efficiency and Xmax required, but I have not seen a polar measurement. Does anyone have polar plots of a 10" midbass with (+/- 40) directivity at 2000Hz?
For a dipole, you may get the best sound by removing both TPL-200H horn and rear chamber and allow it to work as a wide dispersion dipole tweeter. To match the wide dispersion of the TPL-200 dipole at a 2000Hz crossover, you may need to consider a 6" - 7" midrange with a small size NdFeB motor providing free dipole air flow, plus adding a 10" midbass between your 18" woofer. Naturally, this dipole will be a much lower efficiency speaker design than a sealed box design. B&C NdFeB speakers like the 6NDL38 with Qts=0.42 have positive comments.
Old 28th May 2015, 04:27 AM   #30
manninen's Avatar
0011 15W750 - Low Frequency 15W750 : Eighteen Sound - professional loudspeakers
0010 15ND930 - 15ND930 : Eighteen Sound - professional loudspeakers
https://m.thomann.de/fi/eminence_deltalite_ii_2515.htm
Could be the nd930. heard that deltalite is good.
Nd930 is used in finnish diy nitrosäiliö, low inductance. W750 is more heavyweight.
All of these have some little peaks on impedance graphs.
Polar response is new thing for me, i think i'll take the horn off and go some 6.5". eighteen sound has good 6,5"'s, phl aint much open on back
Rundmaus proudly presents... Rundmaus The Lounge 5 12th August 2014 09:53 PM
Presents the National Anthem of Your Country FullRangeMan The Lounge 2 16th August 2012 10:44 PM
Merry Christmas! What did you get for presents? Ninesvnsicks The Lounge 8 29th December 2011 06:41 PM
Brian Wilson presents SMiLE!!! Apogee Music 18 24th November 2004 06:31 PM
Copyright ©1999-2017 diyAudio
