JBL N1200/N8000 Crossover Upgrade - diyAudio
Old 30th March 2015, 07:23 PM   #1
Default JBL N1200/N8000 Crossover Upgrade
Hi.
Looking to replace my JBL crossovers with a single 3-way crossover. Inspired by the upgrade of the JBL L300 crossover by Nelson Pass. I will be using most of the elements of the original design, but the challenge will be to replace the 1.1mh tapped inductor with an equivalent circuit. It has been suggested i use a 3 ohm series resistor after the parallel 1.1mh coil. Nelson Pass used a 8 ohm series resistor after the series capacitor in his redesign. So, my question is, do i put the 3 ohm series resistor after the series capacitor or after the parallel coil or does it matter?
Thanks, Barry
Old 31st March 2015, 08:48 AM   #2
djk is offline djk
djk's Avatar
No sensible answer may be made without knowing the drivers involved.
Candidates for the Darwin Award should not read this author.
Old 31st March 2015, 12:08 PM   #3
Drivers are: JBL 130A woofer, LE175 compression driver on a 1217-1290 horn/lense and a 077 slot tweeter.
Old 31st March 2015, 12:24 PM   #4
speaker dave's Avatar
Originally Posted by zenbar View Post
Hi.
Thanks, Barry
There will be a subtle difference. As with all tweeter filters, if you pad with a resistor at the back end of the filter you are essentially increasing the load resistance and the corner Q of the filter will sharpen. If you put a resistor at the front of the circuit (and before or after the capacitor doesn't make any difference, it is before the inductor) then the corner Q will soften.
Note that these early JBL crossovers are very generic and you can do much better designing a crossover for your specific system.
David
Old 31st March 2015, 02:28 PM   #5
Anyone have a better crossover design for this set of drivers? I can solder up a crossover from a schematic, but crossover design is beyond me. Any suggestions on how to improve these old JBL crossovers? Cabinets are ported 6 cu. ft., similar in size and shape to the JBL L220 and tuned to 45 hz.
Old 22nd May 2015, 08:21 AM   #6
Default Suggestions
I have built similar systems with Elliot active crossovers and bi or tri-amping the system. The frequencies are 1200Hz and 8000Hz.
To design active crossovers takes quite a bit of research, unless you just want to throw something together. Parts-Express has a three-way 12db pcb. You can estimate a crossover, but it is better to get a zobel network and L-pad attenuator in there.
Old 22nd May 2015, 08:37 AM   #7
A second thought, most likely only the capacitors would degrade. You could replace them, even though you may have to use parallel caps to get the closest values; but anything within 20% would be adequate. Dayton audio has polypropylene at 12uF, 12 + 1.5, and 15 + 1.5 to get very close values at better than 5%.
JBL L100 restoration and upgrade leesonic Multi-Way 12 5th September 2013 10:44 PM
crossover upgrade leonm12 Multi-Way 28 23rd February 2012 09:36 AM
jbl control one upgrade. londondan Multi-Way 3 15th May 2011 10:24 PM
JBL 300.4 amp upgrade/mods ahmisuhairi Car Audio 6 26th September 2007 06:34 AM
JBL 4343 - 4344 upgrade thread macka Multi-Way 11 18th September 2005 09:39 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
