Effect of xover on low frequency - diyAudio
Old 28th March 2015, 06:18 PM   #1
Default Effect of xover on low frequency
I have found some very old measurements that I took when looking at the affect of a passive low pass sub woofer filter that I found.
The measurements were as follows in dB
1/3rd octave Hz 100 125 160 200 250 320
Full range 70 68 63 59 60 64
With coil+cap 73 73 67 58 52 -
With coil alone 71 69 65 59 56 57
What interests me is that the output is higher with the coil, and higher again with the coil+cap. Is this normal, or does it reflect on my crude measuring.
Old 28th March 2015, 07:39 PM   #2
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Hi midrange,
It is normal as long as the impedance is not flattened.
2nd order without and with series RLC in parallel with
the driver.
Old 28th March 2015, 11:53 PM   #3
Thanks. Sorry that the "table" got out of alignment when it appeared in the thread.
Is this effect on the bass increased and decreased depending on the values of the xover components?
Old 29th March 2015, 11:59 AM   #4
Lojzek's Avatar
Yes, the lower you make your XO point the more it gets pronounced.
Old 29th March 2015, 01:24 PM   #5
Thank you very much Lojzek. Not something I have come across in descriptions of xovers.
ebay 2.1 cheapo amplifier xover frequency arjen Class D 0 12th March 2015 10:24 PM
Effect of change in Switching frequency ??? apocalipsis1234 Class D 4 5th October 2014 07:15 PM
Has anybody listened to the effect of xovers vs no xover? makingmoney Multi-Way 16 11th June 2010 08:26 PM
perfect xover frequency PeteMcK Multi-Way 4 6th June 2010 11:39 PM
Need to change passive xover frequency georgehifi Multi-Way 17 6th October 2006 12:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
