Speakerholic
I looked at the previous thread, but I have questions still.
I have a set of 10" woofers that I want to to convert to drones. They are a pulp cone and have a paper dust cap. I want to remove the magnets and coils but leave the spiders for a more lineal throw. I was thinking of painting the back of the cone with white glue to stiffen. Maybe a few coats, I don't know. I would also paint the dust cap from the back side. I was thinking of adding lots of glue to the back of the dust cap to add a little weight. I have done this before, but never got the completed system checked. It sounded just fine. Now, if I'm going spend a little time doing this I'd like to know if I'm heading in the right direction or not. It won't cost anything to do it, but are passives still used to good effect in 8" two way's? Thanks for your time Cal |
#2 | |
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#3 |
Assuming they have enough excursion to be of any use, bonding a flat plywood disc to the cone with insulation in the hollow works well, and if you leave the VC attached you can fill it as required to fine tune it.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#4 |
Speakerholic
OK, I can always go easy on the glue.
Plywood? Haven't I created a stiff and heavy cone with the glue? Need it be another diaphragm? Would this be panelling thickness I'm guessing? It sounds like work to me there GM. I was hoping to get by on the lazy side. Besides the finishing on the plywood would more work than it's worth. No? Cal |
#5 | |
diyAudio Moderator Emeritus
PR's aren't easy. You will need to use mass to tune them as you would change the length and diameter in tuning a port. The problem is you don't have any software to tell you exactly how much mass to add (or remove) to make the PR resonate at the correct frequency. You will have to do this by trial-and-error.
Rodd Yamashita |
#6 |
>Plywood?
==== Well, it has to be void free and resonate well above the PR's BW. HDF should work if its tuned low enough. ==== >Haven't I created a stiff and heavy cone with the glue? ==== Beats me, I'm not familiar with the driver's construction or how thick a white glue you're using. Since the white glue I'm familiar with isn't very massive and doesn't dry very hard, I doubt it though. ==== >Need it be another diaphragm? Would this be panelling thickness I'm guessing? ==== No, it will need to be at least 1/2" thick, but mostly it depends on how much mass needs adding. ==== >It sounds like work to me there GM. I was hoping to get by on the lazy side. ==== Well, to my way of thinking, gluing a wood disc on IS the lazy/quick way, and why I suggested it. Anybody who knows me well knows I was born lazy and immediately had a relapse. ==== >Besides the finishing on the plywood would more work than it's worth. No? ==== Since when is a fine finish a prerequisite to good performance? Sounds like you're trying to make work for yourself. GM
#7 | |
#8 | |
are a number of proviso's to be considered : The 10" driver must be a long throw design, with a larger suspension excursion (and its larger cone area) it could work well with an 8" bass/mid driver. There is the possibility of leaving the magnets in place : connecting a variable resistor across the terminals will then give control over the damping of the reflex action. Removing the magnets is relatively easy, removing the coil is not, I can't see the point of removing the coil. Adding mass to the back of the cone is awkward due to the chassis, adding to the front is a lot easier. I'd suggest spraying the front via a circular stencil with car underbody anti chip spray, heavy and good damping. If you want to stiffen the cone first spray it with black hammerite or similar paint. In both cases add in thin layers and allow plenty of time between layers, and using a proper spraying pattern will ensure an even coverage of the cone. Adding mass inside the voice coil is a possibility, find stainless washers that fit and epoxy into place. (If you are removing the magnets, I can't see the point) To answer your final point, a reflex port is far cheaper and almost as effective is any medium sized and above 8" two way speaker. Generally the extra cost of a passive radiator is not worth the minor extra performance. However in a medium sized enclosure ridiculous amounts of mass will not be needed to be added to the driver, and the possibility of variable damping is an advantage. |
#9 | |
Software? Bullock and White's Boxmodel will tell you two things: A) What the Mass of the cone is already just from the following Thiele-Small specs: Fs, Vas, Qes, Qms, Re, (DC resistance) Sd, (Area of cone) Actually, the area of a 10 incher is always around 56 sq inches or 350 sq cm. B) What the mass required is to tune the box to the desired frequency. You then subtract the mass of the cone you just looked up or calculated from this amount. I agree with the others that assuming your cone excursion is about equal to your projected active speaker, you should use a speaker no larger than an 8". Here is the link. http://www.hal-pc.org/~bwhitejr/ Note: When downloaded, you will get several programs when unzipped, like a program to predict bandpass enclousures, crossovers, and Transmission Lines. Do not use the Transmission Line program-it was an experimental model that Bullock later admitted did not predict results. The other programs are perfectly fine, however.
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#10 |
Speakerholic
It was going to be an 8" two way.
Alas, I feel the wind retreating from my sails. Perhaps best to acknowledge the difficulties and return to a tuned port, like the rest of the sheep. Baaah...d news for the old woofers Thank you for your answers Cal |
| Cone weight vs Cone stiffness | musgofasa | Full Range | 9 | 25th July 2008 08:16 PM |
| Sub Cone material | skooter | Car Audio | 24 | 23rd November 2007 07:53 PM |
| Too much pressue on cone? | K-amps | Multi-Way | 4 | 26th July 2007 01:44 AM |
| Making a cone | rjb | Full Range | 24 | 28th February 2006 09:24 PM |
| Page generated in 0.12985 seconds (82.61% PHP - 17.39% MySQL) with 11 queries |
